Vibration at 60mph.
Old Jun 6, 2002 | 06:35 PM
devilfish's Avatar
devilfish
Default Vibration at 60mph.
I get some minor vibration in the steeringwheel at 60mph and over. I swaped the tiers from my "old" 91 to my "new" 91. Must I rebalance the tiers?
Regards
Old Jun 6, 2002 | 07:56 PM
Husker Vette's Avatar
Husker Vette
From: Are you the bug or are you the windshield.....
Default Re: Vibration at 60mph. (devilfish)
Regards
did you have the vibration beofre you switched the tires? If not then yes on the rebalance.
Old Jun 6, 2002 | 08:00 PM
85WHITEZ51's Avatar
85WHITEZ51
Default Re: Vibration at 60mph. (Husker Vette)
Had the same problem. Does it get worse the faster you go? Mine did and it turned out to be a bent wheel from the manufacture. Looked perfect untill I got it on a high speed balancer.
Old Jun 7, 2002 | 10:25 AM
devilfish's Avatar
devilfish
Default Re: Vibration at 60mph. (85WHITEZ51)
My old 91 with the same tries dident vibrate. But my "new" 91 with the same tires do.. ? Strange
Old Jun 7, 2002 | 10:51 AM
92TripleBlack's Avatar
92TripleBlack
Mach 1. Check to make sure they are proprerly balanced. You may have thrown a weight.
PTz-92-LT1's Avatar
PTz-92-LT1
The vibration you are experiencing may be a by product of a variety of issues, among them are: out of balance wheel; seperating tread; bent rim; incorrect mounting; or out of round tires.
You mentioned that you just swapped the tires from one care to another. How long was that car sitting, you may have flat spots which may work themselves out.
How many miles were on those tires since last balance? If the tires had some excessive where, like burn-outs that will through the balance off.
So I guess all this is to say, look at the tires and rule out out of round, tread seperation and bent rim. Then just spend $10 and get them balanced.
Regards
Old Jun 7, 2002 | 12:04 PM
98NYFINESTVETTE's Avatar
98NYFINESTVETTE
From: 10.70 @ 124mph, Stock Bottom End @ 3620lbs, ECS Racing Team Member. The 1st NMCA LSX Index Rumble World Champion. 2011,12,13 Champion
Check tire balance and outer tie rods. I had a vibration and it was the outer tie rods. The tie rods where pretty bad. Then I rebalanced the tires in case the vibration moved any of the weights.
Old Jun 7, 2002 | 12:18 PM
devilfish's Avatar
devilfish
Default Re: Vibration at 60mph. (89NYFINESTVETTE)
thanks. Will check that....
Old Jun 7, 2002 | 03:21 PM
guywade's Avatar
guywade
wheel bearings? or out of round tires, can cause this too! :D
Old Jun 7, 2002 | 03:25 PM
devilfish's Avatar
devilfish
Default Re: Vibration at 60mph. (guywade)
i noticed that the vibration stoped at 130mph ;) I think I need a alginment, the car is lowerd and I dont think its been "fixed" after that.. cheers
Old Jun 7, 2002 | 06:35 PM
HittinD.Apex's Avatar
HittinD.Apex
I had the same exact problem - "tiers" needed to be balanced. :yesnod:
To Vibration at 60mph.
