1987 c4
Old Nov 10, 2012 | 12:56 PM
lesterb's Avatar
lesterb
2nd Gear
Default 1987 c4
how can i start this 87 thats been sitting for 4yr it has no fuel lines to
engine.it is complete and turns over.
Old Nov 10, 2012 | 11:47 PM
1986coupe's Avatar
1986coupe
No fuel lines to the engine? Is the entire TPI there?
Put some fuel lines on. Otherwise you would need to get fuel into the system through the TPI to see if it will start. Not a wise way to do it though.
Old Nov 11, 2012 | 12:56 AM
vetteoz's Avatar
vetteoz
http://forums.corvetteforum.com/c4-t...-87-c-4-a.html
Old Nov 11, 2012 | 07:22 PM
red89c4's Avatar
red89c4
squirt fuel into the TB while turning engine over.
Old Nov 11, 2012 | 07:41 PM
leesvet's Avatar
leesvet
In order for that engine to start and run...the fuel system has to be pressurized AND the computer has to work.
Unless you understand what you are dealing with, all you will do by jury-rigging gas lines that are under 50 psi pressure, is to start a BIG fire.
It takes much more than just getting gas to the engine...its under high pressure and the injectors have to work.
Old Nov 11, 2012 | 07:57 PM
AirForceOne!'s Avatar
AirForceOne!
Sitting for 4 years, fuel lines are only one of many things you will need to attend to after you get her running!
Old Nov 11, 2012 | 09:39 PM
red89c4's Avatar
red89c4
do you want to see if the car will start and run or do you want to drive the car with the fuel lines off?
squirting fuel in the throttle body will allow the car to start and run just like a carburetor engine. it is probably not the safest way but it will work. in order for an internal combustion engine to run you must have 3 things, spark, combustion, and fuel
To 1987 c4
