Can anyone tell me if the current sensor in my car, looks like a spark plug with a porcelin top, was replaced with another sensor currently available for the car?
Reason I am asking as this was never replaced in the car and the porcelin tip seperated and will not come out of the connector. I was wondering if anyone has replaced with the newly available sensor and changed the wire harness.
Thank you in advance.
Is it at the front of the intake, under the air pump? If so, thats the coolant temp sensor, those ealy ones had a connector like a knock sensor, except w/ 2 wires. They were trouble some, thats why they have an updated design.
Or visit your local junk yard. Any tbi equipped truck will have it, almost everything after 1985 had that. You don't have to worry about which wire goes where.
