Where do I get a drive shaft protector?
Old Jun 7, 2002 | 12:55 AM
Kieran Cox's Avatar
Kieran Cox
Default Where do I get a drive shaft protector?
I have heard bad things about when a U-joint breaks! I a have also head you can get a protective loop to guard the car against possible damage when a U-joint goes.
NE1 know where I can get one of these? :confused:
.... and the usual How Much? and How hard to install?
:p:
Old Jun 7, 2002 | 05:08 AM
pablocruise's Avatar
pablocruise
Default Re: Where do I get a drive shaft protector? (Kieran ***)
I got mine from Summit. Like $20.00 bucks. It was quite tricky to install!
You have mail with pics on my install.
Old Jun 7, 2002 | 07:05 AM
98NYFINESTVETTE's Avatar
98NYFINESTVETTE
From: 10.70 @ 124mph, Stock Bottom End @ 3620lbs, ECS Racing Team Member. The 1st NMCA LSX Index Rumble World Champion. 2011,12,13 Champion
You can order one from Summit or Jegs.
Old Jun 7, 2002 | 12:32 PM
Kieran Cox's Avatar
Kieran Cox
Default Re: Where do I get a drive shaft protector? (89NYFINESTVETTE)
Thanks for the info. I'll be ordering one immediately! :yesnod:
To Where do I get a drive shaft protector?
