Another Issue: Stalled while on highway
Old Nov 13, 2012 | 04:27 AM
oifcombatvet's Avatar
oifcombatvet
Default Another Issue: Stalled while on highway
First time this has happened, driving my 1989 Corvette at slower speeds, probably around 45-50mph for approximately 2 miles drove just fine. Got on the highway and opened it up a little bit on the on ramp, probably to 75 or so, whole thing shut down, stalled. Coasted to a stop on the shoulder of the highway. It cranked and cranked until the battery went dead. I have fuel pressure. I am going to check for spark as soon as I have the time.
Any other things it could be?
Thanks in advance.
Old Nov 13, 2012 | 09:01 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Fuses - IIRC there is a fuse for the ECM and one for each bank of injectors
Old Nov 25, 2012 | 08:33 AM
gunnerjuju's Avatar
gunnerjuju
Did you ever figure out what happened?
Old Nov 25, 2012 | 10:49 AM
hangon123's Avatar
hangon123
Cruising
Default HangonII
Hi, I have a 86 C4 and have been having low RPM stalling for months. It would fix itself after using fuel adative but then the problem would reapear. There were no codes and the fuel pressure would build up. This last time however, the fuel pressure would not hold. My book said the problem was a leaky injector or a bad pressure regulator. Bunko, It was the fuel pump. The pump itself needs to hold pressure. I replaced the fuel pump which is easy on the C4 and not expensive. The result is that I'm now convinced that my car needed a new fuel pump for the last 30K miles of driving. The car is fixed and drives normal. If your car pulsates when on cruise control at about 35 MPH, it needs a new fuel pump. Hope this experince helps my fellow C4 owners.
Old Nov 26, 2012 | 04:15 PM
oifcombatvet
I did figure out what happened. The larger black pigtail that plugs into the distributor cap had a broken clip and it slipped out of place.
For the first time since owning this Corvette I finally have it running pretty good *KNOCK ON WOOD*
Thanks to this forum and all the great advice I have gotten on it.
Old Nov 26, 2012 | 06:01 PM
hangon123's Avatar
hangon123
Cruising
Default HangonII
Hi, I have the repair manual for my 86 and it comes in handy for troubleshooting. Your problem was easy to find because it was probably constant. My problem was intermitant and dependant on atmospheric conditions. The ECM makes these problems difficult to troubleshoot.
To Another Issue: Stalled while on highway
