1988 auto
Old Nov 13, 2012 | 08:14 PM
John.87's Avatar
John.87
Default 1988 auto
Sometimes while cruising at 50-65 in overdrive, the dash light to shift up will pop on until I either get off or get into the gas. I was surprised there was even a bulb in it considering its an automatic. Thoughts?
Old Nov 14, 2012 | 07:31 AM
AirForceOne!'s Avatar
AirForceOne!
That would be annoying, I'm sure there is a way to disconnect it!
Old Nov 14, 2012 | 07:57 AM
XR_Strider_GuY's Avatar
XR_Strider_GuY
From what I know this will light up if you are in a lower gear and going faster than 45mph (from memory). I get this dash light come on when I am cruising through twisty roads driving with the shifter out of Over Drive. Just an idiot light.
In full over drive mode i find that it occasionally lights when going up hill. Since its related to the shifter I think when going up hill it thinks the shifter is not in over drive. I just go into non over drive and then back and the switch goes off.
Glad mine is not the only one doing this occasionally. SO I have a normal C4 right?
Old Nov 14, 2012 | 08:16 AM
SuperL98's Avatar
SuperL98
Here are the shift light controls in the ECM code for the 88 Auto
Old Nov 14, 2012 | 08:59 AM
AirForceOne!
I have never seen mine go on!
To 1988 auto
