head lights
Old Nov 17, 2012 | 06:56 PM
'93 Hugrr's Avatar
'93 Hugrr
Cruising
Default head lights
i have a '93 c4 LT1 i just got , when i turn on my head lights after they have opened i hear a clicking on one side , about 7or 8 clicks and then it stops, my question is this, is there a trim setting i can adjust on the head light motor . thanx for any help.
Old Nov 17, 2012 | 07:19 PM
1985 Corvette's Avatar
1985 Corvette
Sounds like the plastic gear inside the motor has chewed itself up. Not a big deal to replace if anything it's more of a pain to make sure the headlight in the closed position's gaps are right.
Old Nov 17, 2012 | 07:21 PM
oilyfishhead's Avatar
oilyfishhead
Sounds like time to rebuild the drive. It's not hard.
http://www.ecklerscorvette.com/corve...1988-1996.html
Old Nov 17, 2012 | 07:36 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
You probably have bushings going bad inside the gear..
http://willcoxcorvette.com/product_i...oducts_id=5106
Could be the gear but this motor is famous for the Delron bushings wearing out. Watch the video below and you'll see what is causing your problem.
I never use the brass gears nor do I endorse them...
The gear was designed in plastic and should a failure occur it will not take out the drive gear. If you put brass in there and you have a failure you will destroy the motor. This is basically the same reason GM replaced the second metal worm gear in the 53-77 W series speedo heads with a plastic one and I wish they had done this years and years ago...
But.. I don't think your issue is the large gear, 95 percent of the time the three bushings are wearing out.
http://willcoxcorvette.com/product_i...ducts_id=18813
And here is how to fix it.
Headlamp Motor Removal and Rebuild 88-96
Old Nov 18, 2012 | 08:39 AM
'93 Hugrr's Avatar
'93 Hugrr
Cruising
Default head light
thank you for the info. this is a big help for getting started .
Old Nov 18, 2012 | 09:39 AM
BGZQ8's Avatar
BGZQ8
OK I have a follow-up question. My lights open and close with no clicks or clunks, but both motors continue to spin (equal amount of time each) for 2 or 3 seconds after they are fully open or closed. Is it normal for the motors to run for a couple of seconds (no weird noises) after the rotation stops ?
Old Nov 18, 2012 | 10:44 AM
1985 Corvette
Once the stop comes into contact with the hood when the lights close, it should definitely cut all power at that moment. Mine did that too: open partially with lots of loud clicking, I would have to get out and rotate it into its fully up position. The lights would flip back into the closed position no problem, but because of the stripped gears, they would continue to run.
I have never had problems with the bushings, though they should not be overlooked. It was always the gears coming apart.
Old Nov 18, 2012 | 11:25 AM
BGZQ8's Avatar
BGZQ8
But mine open and close fully on their own without any clicking at all. Smooth as silk. I just wanted to know if it was normal for the motor "*****" to continue to spin for 2 or 3 seconds after the lights come to a stop. BTW the motors both stop spinning at the same time also.
Old Nov 18, 2012 | 12:21 PM
Hooked on Vettes's Avatar
Hooked on Vettes
The motors should turn off immediately when they are fully opened or closed.
There were two style of motors. 84-87 and 88-96.
84-87 motors used mechanical switches to turn the motors
on and off and 3 mechanical relays to determine what direction the motors turned. This style motor used no delrin
bushings and the failure was usually stripped teeth on the driven gear, magnets coming unglued inside the housing or bad switches.
88-96 motors were controlled by a electronic control module that monitored the current draw from each motor.
When the 3 delrin bushings wear out they allow excessive
slippage so the motor continues to run until the motor draws enough current for the control module to shut them off.
The delrin bushings act as a clutch to allow the motor to
absorb the shock when it makes contact with the stop,
Replacing the 3 bushings in the motor usually cures
the problem in the 88-96 headlight motors.
You can purchase the bushings at any auto part store
that sells Dorman products. They are usually found in
the HELP isle. Dorman 74410 is the part number. They are
also used in Ford power window motors. Yes you can
find them cheaper on line but by the time you pay for shipping the price is the same. You would need 2 sets since
they come 3 to a package.
Old Nov 19, 2012 | 07:25 AM
'93 Hugrr's Avatar
'93 Hugrr
Cruising
thanx for the info. these part no. will also help. jacob
Old Nov 19, 2012 | 07:37 AM
'93 Hugrr's Avatar
'93 Hugrr
Cruising
great how to video , thanx
Old Nov 19, 2012 | 08:43 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Here is link, follow the instructions, very easy and less then two hours to complete, just take your time.
http://home.comcast.net/~zrjuan/headlight.html
Old Nov 20, 2012 | 03:27 PM
PirateW5's Avatar
PirateW5
While you have it all apart I'd replace the 2 nylon bushings on the pivot shaft. You can order them from this place. Stopped all the wobble on mine.
http://www.mcmaster.com/#snap-in-bearings/=intfl9
Old Nov 22, 2012 | 07:07 AM
'93 Hugrr's Avatar
'93 Hugrr
Cruising
got the kit , gear and bushings and dove in . thanx to the "how to video and great help 3 hrs. later both head lamps were done and working perfectly . this job is ez , if i can do it so can you.
Old Nov 22, 2012 | 09:24 AM
FletchUSMC's Avatar
FletchUSMC
Pirate, which pivot shaft bushings (part number) did you get to replace yours? I recently fixed my headlight motors and noticed these were worn, thanks for the link as I didn't know how I was going to find these little things!
To head lights
