Should I even invest in a different cam if I plan on running about 8lbs of boost? Streetability being a prime concern (and smog test). Thinking about the Carroll kit.....
What kit are you looking at? Last I checked, there were no supercharger kits emission legal in CA for the L-98.
The good news is blower motors don't need high overlap or outrageous lift / duration; both enemies of streetability and emissions. That being said, blower cams have very similar characteristics to stock:
Low overlap: with a blower you want 114-116 LSA so the pressurized intake doesn't blow right thru to the exhaust.
Intake: Don't go crazy on duration/lift; this keeps it streetable with decent emissions. And at higher rpm the blower will kick in and force feed it anyway.
Exhaust: This is where the blower motor needs the most help- getting everything out; think 12-20 degrees longer and .020-.040 higher lift than the intake. (And 1.625" exhaust valves don't hurt either.)
With low boost on a stock 350, your existing cam isn't bad. If your looking for more (especially with higher flowing intake and headers, etc), I'd try one of CompCams hyd-roller blower cams, 212/224. They also have 218/230, 224/236 profiles (good for larger displacement); but understand these will sacrifice some low end and produce more emissions on your 350.
FWIW, I run 215/234 @114LSA with .480/.510 lift on my 383 blower motor; see info in sig...
What kind of times are you getting with your setup?
Haven't been to PIR yet, but my best times at Firebird are 1min-12sec on East track; 1min-15sec on the Main track. These times are still with street tires; I have an extra set of wheels but haven't come up with $$$ yet for Kumhos or Goodyear racing slicks.
On my previous 350, I ran a TPIS HR (114LSA, 224/224 @ 0.050 with 0.566/0.566 I/E). The full street weight '87 roadster never got into the 10's, but ran very high 120s in the quarter. Basically the combo was a stock short block, 8 psi (smallest pulley made delivered 1300 cfm @ 5800 RPM), heavily worked Superram, 58MM, long tubes, massive heads (had used AFR190RRs prior), ZF6, 3.45D44, running slicks. My big problem was with traction (60 ft5 was consistantly above 2.30 sec and went as high as 3.30 sec on slicks).
With more cubes, D-1 equiped 408 uses a CC SR (114LSA, 242/244 @ 0.050 with 0.628/0.644 I/E). With a MRII, AFR215CP (2.08" I / 1.625" E valve) the new unit should run to 6700 RPM, if I ever get a decent engine management system.
GCrouse has the right idea as far as specs are concerned in SC vs NA applications.
