off set?
Old Nov 21, 2012 | 09:03 AM
'93 Hugrr's Avatar
'93 Hugrr
Cruising
Default off set?
I am thinking of new wheels for my '93 c4 LT1 and don't know what would fit, and what does "off set" mean, I know what is on now , 17's and i 'm guessing the fronts are 7.5 and rears are 8.5 ? this being a cost of a grand or so i want to get it right. any info. would be most appreciated . thanx.
Old Nov 21, 2012 | 09:20 AM
WVZR-1's Avatar
WVZR-1
Your '93 if it's a base car has 8.5" wheels front and 9.5" wheels in the rear. A confirmation of this would be tire sizes 255/45 front and 285/40 rears. There's a certification label on the drivers door that displays original tire sizes as built.
If your certification label displays 275/40 for both front and rear check the SPID label on the console door for RPO Z07 - that would mean the car "as built" had 9.5" wheels X 4.
The offset on your wheels regardless of width is 56mm. If you were to change wheels it might be wise to stick with a "very" similar offset, if you'd like to be able to rotate tires do all four the same and you'd like a wheel center bore of 70.3mm for fit to hub.
If you're shopping you might want to come back with your interests before buying and being disappointed.
Old Nov 21, 2012 | 09:27 AM
'93 Hugrr's Avatar
'93 Hugrr
Cruising
thank you for the help. i'll check the labels on door and console , but what does does off set mean? just would like to understand .
Old Nov 21, 2012 | 09:32 AM
WVZR-1's Avatar
WVZR-1
It's the dimension from the center of the wheel to the mounting flange of the wheel where it bolts to the hub/rotor. It can be a positive number(outboard) or negative number(inboard) of the wheel center line.
Google "wheel offset" and also "wheel back-spacing" There's many tutorials!
Old Nov 21, 2012 | 09:37 AM
'93 Hugrr's Avatar
'93 Hugrr
Cruising
ok . thank you , you been a great help, have a happy thanksgiving !!
To off set?
