These damn bolts won't budge
Old Jun 7, 2002 | 10:49 PM
chucks88's Avatar
chucks88
Default These damn bolts won't budge
:mad I'm trying to remove my drivers side hub/bearing, it's on its way out. These are shots of the 3 Torx 55 bolts keeping the hub on. Excluding one of the pics they appear to be fairly free from rust.
I have spent at least 6 hours trying to get these loose. They have been hit for 3 days with PB Blaster and heated. I haven't heated the bolt head side as I don't think I can get in there with the propane torch. I have been heating the side closest to the hub (thread side)
I didn't remove the drive shaft. I'm not having any problems reaching the bolts.
Is there anything else I can try to get them loose. I have been using long breaker bars.
As a side note the 36mm nut that is suppose to be torqued down to about 165 ft. lbs. was just a hair over hand tight :eek: That may be my culprit. I'll have to check the 36mm nut on the other side also
Old Jun 7, 2002 | 10:55 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: These damn bolts won't budge (chucks88)
Is there enough room to get the torx driver on it and put an extension on and then use an air impact gun? I can't remember if there is enough room. I changed one of my wheel bearings and didn't have any trouble. Good luck.
Old Jun 7, 2002 | 11:05 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Soak that sucker in Liquid Wrench, put an extension on Torx bit and give it a copla raps with a small ball peen. Do this several times if necessary.
I used this method on my stuborn EGR pipe Torx bolts and it worked like a champ.
Old Jun 7, 2002 | 11:11 PM
M2001's Avatar
M2001
I have a 3/4" air impact wrench. It never came across a bolt it couldn't take off. Go air on this one!
Old Jun 7, 2002 | 11:24 PM
chucks88's Avatar
chucks88
Default Re: These damn bolts won't budge (M2001)
I should have let you guys know that I dont have access to air :nonod:
Old Jun 7, 2002 | 11:38 PM
M2001's Avatar
M2001
You have to buy yourself an air compressor. For about $300-$400, you can buy a decent compressor and you'll be using it for years. I bought mine at Costco many years ago and I use it for everything. Go air my friend, you won't regret it.
Old Jun 7, 2002 | 11:58 PM
Bluevette85's Avatar
Bluevette85
I got mine off using a 24" breaker-bar then sliding a 2 foot piece of metal pipe 8 inches over the bar. With that much leverage, it came off!
Old Jun 8, 2002 | 12:02 AM
LT5's Avatar
LT5
Old Jun 8, 2002 | 02:49 AM
vanduker's Avatar
vanduker
Even if you don't have a compressor yourself, chances are you know someone who does and has a portable air tank as well. Even a 10 or 15 gallon air tank is enough to run an impact wrench to bust these loose.
Take it from a puny little nerd. I tried stuff like this with all variations of cheater bars before I got the compressor. I now take the air tank and impact with me when I go to other folks houses to help 'em wrench on stuff.
Mark
Old Jun 8, 2002 | 02:55 AM
ZAD54's Avatar
ZAD54
Default Re: These damn bolts won't budge (vanduker)
Have you tried an impact driver? Smack that sucker with a hammer and see if it breaks them loose? Good luck :cheers:
Old Jun 8, 2002 | 02:56 AM
Kieran Cox's Avatar
Kieran Cox
I got the 30 gallon 6hp one from Sears. Works nice! :yesnod:
Althought I would really hesitate to let a torx bolt have the impact wrench. Those things stip out easy.
Old Jun 8, 2002 | 03:17 AM
Aggravated4life's Avatar
Aggravated4life
Default Re: These damn bolts won't budge (Bluevette85)
This is the way to do it without air tools.I had the SAME problem with the 3 torx bolts on the rear hub.It would NOT come off for anything.I was using a 12 inch breaker bar and it wouldnt budge.
It was too short for leverage.
You need a good 20-24 inch bar and some good clearance from the floor to crack free the bolts.The longer the bar,the easier it is.The really long breaker bars at 20+inches has always allowed me to get bolts free my impact guns had problems with stripping.
Since youre on the drivers side,your bar may be hitting the floor to loosen.That was my main problem.Couldnt get the bar anywhere without it hitting the floor or a suspension part.You need to get the car a little higher if thats the case and once it cracks free,it will come off with a regular ratchet after.
And yes,do soak the front of the bolts with pen. oil overnight.Dont use heat on aluminum parts.It will make it worse.
Remember,the longer the bar,the easier it is.The 12-15 inch bars wont loosen them back there.
Old Jun 8, 2002 | 03:27 AM
Jay Axson's Avatar
Jay Axson
All the suggestions should work, impact driver, impact gun, breaker bar with pipe on handle. I didn't notice anyone suggest heating with a hot torch. Bolts come out like butter when red hot. If the heat will damage anything around or behind, or is near fuel / flamable stuff don't use it!
[Modified by Jay Axson, 1:28 AM 6/8/2002]
Old Jun 8, 2002 | 07:15 AM
GS Ragtop's Avatar
GS Ragtop
From: Michigan in the summer, Florida the rest of the time
St. Jude Donor '08-'09-'11
I just bought a couple of "helpers" - went to Home Depot and had them cut me two pieces of pipe (one 1.5" diameter and one 2"), 24" long. Instead of threading the ends, they just chamfered them to remove the sharp edges.
Cost 12 bucks for the two. Now I have kong-sized leverage. :lol:
Brad
Old Jun 8, 2002 | 08:49 AM
JonM's Avatar
JonM
If you are still having trouble call me (469-2526) We'll figure something out. I have a compressor here and plenty of pipe for leverage.
Jon
Old Jun 8, 2002 | 08:57 AM
Sharky Guam's Avatar
Sharky Guam
Default Re: These damn bolts won't budge (GS Ragtop)
If you heat it. Don't heat the bolt. The object is to heat the area around the bolt without getting the bolt up to the same temperature.You need to get it red hot for best results. As it cools, squirt motor oil, not liquid wrench or penetrating oil in the area where the threads are. Sometimes you can bang the round side of a ball peen hammer against the area surrounding the bolt a few times also to loosen the molecules. I have never met a bolt that could not come off with a hot wrench(torch). Usually, it will appear to be only finger tight after the heating session.
:cheers:
Old Jun 8, 2002 | 09:45 AM
chucks88's Avatar
chucks88
Default Re: These damn bolts won't budge (Sharky Guam)
After my coffee it's back down to the garage. I'll try raising it up a little higher to get more leverage. I do have a pipe I slip over my breaker bar but that still didn't seem to work.
Thanks for everybodies response and to Jon for offering me his pipe :lol:
I'll keep ya updated. :seeya
To These damn bolts won't budge
Old Jun 8, 2002 | 12:32 PM
chucks88's Avatar
chucks88
I'm progressing! I got one out. Next Dilema... I don't have enough room for leverage to remove the top bolt. This bar that connects to the center of the carrier is in my way and I want to remove it. I remove the nut and thought the bar would pull right up, but after further inspection it is in there on an angle. So then I jacked up underneath the shock to raise it thinking the angle would change enough for me to pull it up. It didn't.
So if I start threading the nut, on the bar that goes back to the center of the carrier, will that change my angle so I can move that bar that goes back to the center of the carrier. :crazy: for leverage?
These photo's may help.
Old Jun 8, 2002 | 12:49 PM
JonM's Avatar
JonM
You should be able to thread the nut back on (not all the way) and tap it with a hammer (babbit hammer is best) but a block of wood will work also.
Old Jun 8, 2002 | 04:30 PM
Bluevette85
Borrow a Pitman arm puller from Autozone. Don't get a tie rod end puller because the opening isn't wide enough to fit.
