Just replaced my A/C programmer
Old Jun 8, 2002 | 12:05 AM
SouthernSon's Avatar
SouthernSon
Default Just replaced my A/C programmer
My method: remove the six knee bolster carpet screws, 2 outside and 4 inside ( the 2 outside are torx).Remove the metal panel, 2 outside and 2 inside. Remove the one screw holding programmer in place, spread the vacuum lines with fingers in order to get a small flat blade under the cheap little stamped metal retaining nut. Pry it up a small distance so that you may get a hold with small needle nose pliers. Rip that #$%^ out of there. (If you need a little extra pull, think of holding the gonads of the engineer that came up with the mickey mouse idea in the first place). remove the vacuum line manifold and then remove the electrical connection, ( easy, gently pry the two retaining clips off, GENTLY!).
Upon replacement, I found a small piece of rubber tube that slid over the bolt srew of the vacuum line fitting (manifold) and backed it up with a small nut.
A/C controller is now positive and sure. The controller hesitated after the first start as if to say "new hardware detected and is now booting up". :seeya
Old Jun 8, 2002 | 12:09 AM
95wht6spd's Avatar
95wht6spd
Default Re: Just replaced my A/C programmer (southern_son)
Why did you need to replace? My fan sometimes doesn't work, like there is a short or bad connection soemwhere. ( comes on over a sharp bumb)
Old Jun 8, 2002 | 10:16 AM
SouthernSon
I had to replace the programmer in order to direct the vacuum to the correct solenoids so that the air flow would come out of the correct vents (or registers). I could not get the air flow out of the panel vents no matter what I tried on many occasions. Other times the air flow would simply dump out of the defroster and leg vents only. Programmer fixed it right up!
I got it from the Last Detail for $182 w/exchange. I believe your problem sounds more like the controller (in the dash) instead of the programmer.
Old Jun 10, 2002 | 11:25 PM
FrankLT4CE's Avatar
FrankLT4CE
Congratulations. !!! How did you determine your problem would be solved by a new programmer? FrankLT4CE
Old Jun 11, 2002 | 01:59 AM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
Default Re: Just replaced my A/C programmer (95wht6spd)
Could be solder joint on the controller or the programmer or a loose wire. The leds on the controller on the dash got flaky on mine which appeared to be poorly done solder joints.
To Just replaced my A/C programmer
