Hood springs
I see a slot for a screwdriver but could not get it to turn. I did not want to force it with vise grip as it does not appear to be metal.
Do these adjust? I see threads on the pin that holds the spring.
Thx
Also clean the whole area and apply white litium grease.
Lube your pull cables too...
and get a hair cut! :P
Sometimes you can get a better release by moving the pin in relation to the latch. The pin should go into the center of the latch. The factory recommended method is to put white grease on the latch and see how the pin wipes away the grease, which shows which direction to move the pin. I saw a post where the guy put masking tape on the latch and grease on the pin and lowered the hood until the pin touched the masking tape.
You can buy a GM hood latch upgrade kit that has heavier springs (the springs are no longer available separately). I have seen these kits for $189, so I decided to live with lifting the hood while pulling the release handle... If you are able to somehow find the heavier springs, they have larger diameter spring retainers, so you need those too.
Thats NOT your problem.
Those springs are to cushion the closing and hold the latch tight so the hood is not smashed against the solid frame.
IF you start screwing that spring IN to attempt to create spring tension to "help" pop the hood....you WILL end up getting the hood so smashed down (in a bind) on the latch that you will never get it to release again. LOOK at the corners...there are a few little rubber bumper post. Those adjust. Look at the springs in the latch pins...if thosen get screwed IN,...you can "over-close" and lock that thing down forever.
Look for the fresh helper shocks and/or the gas strut. Clean and lube the cable release so its a clean release. With fresh shocks it will once again "pop"...for a while at least.
I will try putting some white grease on and see if the pins are aligned. I will also look into the GM latch upgrade.
We used to ajust the pins out on cars so the springs would be less pre-compressed to have the hood pop up better. I mostly did this on cars with one spring in the middle. Not on a Vette.
I did replace the help shocks. I will look for the gas charged prop.
The gas struts' job is NOT to lift the hood that firs inch or so, and the geometry of those lift assist rams is such that there is no possible way that they could. New lift assist rams will not help this situation.
Having said that, they don't generally come out of adjustment or fatigue so issues with the hood not "popping up" are usually related to dirty/not properly lubricated latching mechanisms.
I adjusted the pins back in some and loosened the whole assembly on the hood (passenger side) and let the hood go down slowly which moved it in the right position. I then tightened it up and it worked fine. I also cleaned off the old lube and re-lubed it.
Thanks,
