Piston question
1. Would I need to re-balance my rotating assy.? I'm also using the 'pink' rods with a standard stroke crank.
2. Which rings do I use? I know these have a metric 1.5mm top ring, but not sure about the others. I'm currently considering these:
http://www.summitracing.com/parts/pcr-41497cp
For rings, i build with the gapless (I perfer the top ring to be gapless rather than the second ring). Gapless does wonders for controlling elimination blow by and improving emissions.
Materials are cast, steel, and ductile. Since this is a non-nitrous, OK compression ratio truck motor...it doesnt matter which material. Some will say cast will seal better, some say ductile will handle more pressure-power.
these are for 1.5mm/1.5mm/4.0mm rings (most stock chevys are 3/16,3/16,3/8? so please check your card)
Total Seal Piston Rings T6434-35 -Piston Rings, Ductile Iron, 4.030 in. Bore, 1.5mm, 1.5mm, 4.0mm Thickness, 8-Cylinder, Set $248.95
Total Seal Piston Rings MS6434-35 - Total Seal MS AP Advanced Profiling Ring Sets Piston Rings, Steel, 4.030 in. Bore, 1.5mm, 1.5mm, 4.0mm Thickness, 8-Cylinder, Set. $376.99
Total Seal Piston Rings S6434-30 - Total Seal TSS Street Piston Rings $196
What compression ration are you trying to get?
Throw those "pink" rods AWAY...get some basic aftermarket I-beam rods from eagle or Scat with ARP bolts for reliability.
Stock crank is OK, but why not stroke it...same price (243) excluding having block clearanced (50-100) and using either stroker rods, small base circle cam, or just lucky. I used a set of eagle rods that were not stroker but cleared the cam without issue. Plus that heavy wieght beast will need torque.
