Water pump and master cylinder??
Old Jun 8, 2002 | 04:11 PM
vette40509's Avatar
vette40509
Default Water pump and master cylinder??
For a 93 LT-1 is there a better than stock replacement for the water pump and does anyone know where to purchase a plastic master cylinder reservoir for a 87 Conv. The 87 has the single cup reservoir with the tupa and extension cap reaching the other port, thanks all!!
Old Jun 8, 2002 | 04:36 PM
Husker Vette's Avatar
Husker Vette
From: Are you the bug or are you the windshield.....
Default Re: Water pump and master cylinder?? (vette40509)
I'm sure that someone produces a more high performance water pump than what you have..... probably just need to check around for one.......
Old Jun 8, 2002 | 09:47 PM
Jay Axson's Avatar
Jay Axson
You could go with a Mezier Electric water pump. It will run the same speed no matter what the rpm is, so the engine cools better at low rpm/idle. It is claimed to be a 7-10 HP increase as well.
Old Jun 8, 2002 | 11:39 PM
vettl83's Avatar
vettl83
Default Re: Water pump and master cylinder?? (Jay Axson)
Might check out Flowkooler at http://www.flowkooler.com I have one of their pumps in the CF and it works fine. 84 CF 91 ZR-1 :cheers:
To Water pump and master cylinder??
