tpis mini ram or holley S/Ram
Old Nov 29, 2012 | 10:41 PM
nickpe's Avatar
nickpe
Default tpis mini ram or holley S/Ram
whats r your experience, which one works better with mod motor. heads,cam headders 550 lift
Old Nov 30, 2012 | 12:02 AM
383tpimachine's Avatar
383tpimachine
Im running the stage 3 USM HSR. Never had a mini but I will say it spins to my 5200 redline (rod limited 383) without an issue where the TPI intake wouldnt spin to 4700. I have been to 5500 once and it flashed there quicker than I realized causing me to get a rev limiter box.
my 383 with dart heads and a comp (small) cam made 408/435 to the tire spinning to 5200.
Old Nov 30, 2012 | 12:52 AM
vetteoz's Avatar
vetteoz
Some intake edumacation
http://xtremecarzone.com.au/index.php?showtopic=386
What else you got to go with them ; gears, stall , etc ?
Old Nov 30, 2012 | 08:13 AM
WW7's Avatar
WW7
The Stealth Ram won't fit under a stock hood without cutting....WW
Old Nov 30, 2012 | 03:49 PM
mxnuke's Avatar
mxnuke
Tpis mini ram on my 427,pulls to 7200 rpm all day.Never had any other intake to compare it to though..good luck.
Old Nov 30, 2012 | 04:30 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Anytime you ask for feedback -- of the comparison nature -- it's always advisable to list your combo. I recall your having an extra-large cam which normally would be best matched to the highest-spinning intake. In this case, the mini...which is also the only one that'll fit under a stock hood (without a scoop/cutting). WW7 stated this correctly.
There may still be a custom-made, hard-to-get, long-to-deliver USM version of the HSR available, but it's pricing is similar to the miniram (aka MR). And, used MR's are way easier to come by -- if you want to pursue that route.
So, with your cam, I vote MR.
Old Nov 30, 2012 | 09:23 PM
383vett's Avatar
383vett
You also need to take into account what you are going to use the car for. If it is predominately a street car, you might want to look into a super ram which has a huge flat torque curve. If you are going to spend much time at the races, the mini might be your answer. The super ram is no slouch. I've turned 10,36 with mine.
Old Nov 30, 2012 | 09:41 PM
cumbercr's Avatar
cumbercr
The Super Ram delivers a boat load of torque. Definitely a great choice for the street.
Old Nov 30, 2012 | 09:44 PM
nickpe's Avatar
nickpe
yes 355 gears, 2800 stall, headers
Old Nov 30, 2012 | 09:54 PM
nickpe's Avatar
nickpe
thanks to all. you guy's are great. ill keep u posted.
nick
Old Nov 30, 2012 | 10:16 PM
JackDidley's Avatar
JackDidley
The mini makes good power. I did it for the easy install. The extra power was a bonus.
Old Nov 30, 2012 | 11:10 PM
GREGGPENN's Avatar
GREGGPENN
Man...post your heads and cam too.
Old Dec 1, 2012 | 01:10 PM
nickpe's Avatar
nickpe
solid lift 235/240 dur 530 550 lift. the heads are dart iron 220 heads polished and ported
Old Dec 1, 2012 | 01:56 PM
383vett's Avatar
383vett
Is this lift with 1.5 rockers? With that duration, you could be over .600 lift. You have a pretty stout cam, more than I'm running on my 406. Try the mini.
Old Dec 1, 2012 | 04:19 PM
rlane5's Avatar
rlane5
MR or LT1 conversion intake is the best performance, for the track, with that setup. But if you drive it around on the street, it will have a flat spot at low rpms, below 2500 rpms.
What size is your engine?
Randy
Old Dec 1, 2012 | 07:50 PM
nickpe's Avatar
nickpe
Randy
its a 350 30 over its decked blue printed and bal. two notch piston 10 to 1
Old Dec 1, 2012 | 07:52 PM
nickpe's Avatar
nickpe
is this lift with 1.5 rockers? With that duration, you could be over .600 lift. You have a pretty stout cam, more than i'm running on my 406. Try the mini.
1.6 rr
To tpis mini ram or holley S/Ram
Old Dec 1, 2012 | 08:51 PM
383vett's Avatar
383vett
I'm running a hydraulic roller 230 240 with .625 lift. Works great with the SuperRam. Actually, I just bought a miniram and I'll be trying a back to back comparison next month.
Old Dec 1, 2012 | 09:04 PM
ch@0s's Avatar
ch@0s
Cool! look forward to it. Too bad you cant through the HSR in the mix.
Old Dec 1, 2012 | 09:07 PM
383vett's Avatar
383vett
Got one you can lend me? Oh, I need a hood too.
