From: And on the fifth day, subpoenas were served to Obama senior staff
Re: Lower radiator hose (SoupNazi)
OH! If you are trying to save the hose it's harder when it's stuck.
I use a huge flatblade screwdriver and work around the hose carefully at about 60* angles. Then try carefully twisting and repeat until loose. Usually takes quite a few passes to get it loose, but beware you can damage the radiator so go slow.
Finally when you get fed up you slice the sucker with the razor and put the new hose on. :D
From: Are you the bug or are you the windshield.....
I have found that you can jack the entire car up and lay on your back, or if you take of the passenger tire you can reach in that way and get a good angle without laying on your back......
From: Michigan in the summer, Florida the rest of the time
St. Jude Donor '08-'09-'11
I only had one hose that remained stuck after hitting them with the wife's 1500 Watt dryer. That one popped free once I broke the seal with a flat bladed screwdriver.
well I finally gave up! But i did get the coolant changed, I don't know if this will lower my temperatures but next time I will slice these frigging hoses then clean the radiator then replace with new hoses! I would also like to know if anyone has removed their radiator in 15 minutes like the tech tip said? I'm no mechanic and don't have many tools, but this job is a pain in the ****!
