you mean I was supposed to put the bolts back in?????
Heh, just kidding... :D
Checking it again sounds like a good idea....Thanks. I did use a few washers....I wanted to find some bolts, but in my short search at the local home depot all I could find was washers....no biggie I guess.
You wouldn't happen to remember what size bolts you used putting it back on do you? I'm planning on doing this soon and want to have the right bolts before I take it apart. :seeya
...5/16" fine thread I believe.....they need to be fairly short in order to not scrub the water pump. I ended up using the stock bolts w/ a washer on each one. (bought at home depot)
