Driveline support beam install
Old Jun 8, 2002 | 07:53 PM
87Beast's Avatar
87Beast
Default Driveline support beam install
What's the best and/or easist way to install the driveline supt beam? I've done it before a few years ago but forgot how, all I remember is using a prybar.
Old Jun 8, 2002 | 08:50 PM
Corvette0096's Avatar
Corvette0096
Default Re: Driveline support beam install (87Beast)
I used a Jack and a long drift to get the bolts lined up.. You are like the third guy I have seen from Vancouver, Wa..
Old Jun 8, 2002 | 09:28 PM
Sharky Guam's Avatar
Sharky Guam
Default Re: Driveline support beam install (corvette0096)
I use a portapower hydraulic jack and pump and a couple of tapered punches to align it. It goes in very easy this way.
:seeya :seeya
Old Jun 8, 2002 | 09:44 PM
GRX's Avatar
GRX
You need to work it in installing rear onto the differential and then the front end by lowering a little bit the engine - trans assembly, and then prying the tranny slightly over to give more room between the tunnel and tranny. Use a 2x4 piece of wood for leverage....carefull not to crack the fiberglass tunnel. Once you get it aloongside the tranny lift the tranny SLOW, and supporting the beam as both go up. When a certain height is attained, the beam will simply be alighned with the tranny. Careful when lifting the tranny with a floor jack...secure the car on jackstands!
Old Jun 9, 2002 | 01:57 AM
87Beast's Avatar
87Beast
Alright everyone, I'll try these good tips out tomorrow , thanks all... and corvette0096 if you happen to see someone in a old Nissan Sentra [or black Vette (soon as I get her back on the road)] wave that sould be me.
Old Jun 9, 2002 | 02:00 AM
Corvette0096
I will be looking for the fin..
To Driveline support beam install
