1993 Corvette high voltage
I replaced the alternator today and there was no change at all to the problem. Any idea what else could be causing this other than the alternator?
I got the water pump changed last week, and the car likely overheated when that failed, if that helps.
With the engine off is the Battery voltage normal?
At the alternator case there is the large Red Battery
cable. There is also a small Red wire on the plug
that plugs into the alternator regulator. Verify the
plug connection for the Red wire is good at the regulator.
Both of these Red wires are fusible links A and B and go
to the #1 Fuse Block shown in the diagram.
Make sure the wires show no signs of burn marks or melting and are making a good connection.. They are bolted together at the fuse block with another Red cable which goes to the Battery.
For the Check Gauges light I've included a page from
the service manual that indicates what can cause that
light to come on.
If the Service Engine Soon Light came on when the engine
was running, you need to pull the code by using a paper
clip or piece of wire and short pin A to Pin G.
Turn the ignition On and the codes will be displayed
in the Dash Cluster Digital LCD.
Module 1 is CCM
Module 4 is ECM
Module 9 is ABS/ASR
Diag connector located above drivers right knee pin out
looks like below.
[F|E|D|C|B|A]
[G|H|J|K|L|M]
With the engine off the voltage indicator appears normal, at a little under the middle (like 11 or so volts I believe)
engine to transmission bell housing bolt.
Look at the negative terminal of your battery. It splits
into two Black wires. Follow the two wires. One wire goes
to the chassis/frame and one Black wire goes to the engine block.
The Alternator ground is the Alternator case which is bolted
to the Alternator Bracket which is bolted to the engine block.
If you have a ohm meter verify you have zero resistance
from the Alternator case to the negative terminal of the
battery.
Did the Alternator problem occur after the water pump
was installed?
The Alternator regulator compares the voltage
of the Large red wire with the Small red wire. The regulator
then determines what voltage the Alternator should output
to keep the battery charged. If something is wrong with the
Small red wire such as a bad connection it could cause
your problem.
You can also damage a replacement Alternator if you run
it long enough at maximum output if the original problem
wasn't fixed.
Most auto part stores will check the Alternator for free.
I'll do the ohm meter test when I get home. Thanks again.
If the battery doesn't 'push back' voltage against the alternator's output, it could cause the alternator to run too high a voltage.
11 volts suggests a bad battery/dead cell.
A battery that has 'rested' for a few hours, should show following voltages:
12.66 = fully charged
12.4 = 75%
12.2 = 50%
12.0 = 25%
Less than above suggests a bad battery...
I'll keep an eye on that battery after I fix this wiring and if it doesn't liven back up I'll look at replacing it.
