1/4 mile times
My question is : Does this sound like a stock or modifed run time? I posted my slip on DragTimes.com. The car does have a little miss at idle and will creep up to 230 degrees if I don't keep the AC fans running.
mid 13 is normal for a stock C4. BTW...running the a/c fans doesn;t help anything. The stock tune is designed for temps in the 220-230 range. Your fans will come on when they are programmed to come on..at 226-228. You can use the fans to blow air while waiting to run, but if the car is in good shape it should not be getting very hot sitting there at idle. Should idle and sit at 180 at the most when its 48 degrees outside. You do not want to run it hard if its cold at less than 160. IMO
If you have a misfire that needs to be addressed. Your Opti may need attention and the plugs probably DO. At the age of your car, its a certainty that its time for injectors...just another wear part on a Corvette.
Traction is why God gave us traction control...or precise use of the foot. Wheel spin is pretty normal seeing as how the car was designed to have bottom end pulling power for stop-lite street racing and not a more useful mid range to upper rpm range for the track. The LT did work to address those power band issues of the L98 but its still a low end engine that will spin the tires to pieces but may not break 100 in the 1/4. Strange but true.
Cars with minor mods can see 13...high 12s.
With a decent amount of money (exhaust, headers, intake, runners) you get
to low 12s..
getting into 11s cost $$. 10s is no longer a street car.
Don't ever use the ASR to try to get traction its for street driving. Launch technique is key.
FYI, you'll get more consistent with experience and seat time. I did the same as you when I first started out. All over the place, then 30+ passes later settled down a lot.
OP: You're right in the "fat" of what most decent drivers get out of their LT1/M6 cars. Being that it was your first time, and you mentioned traction issues, I have no doubts that you could get it to go faster and quicker. More info on your run (60', trap, etc) would help us tell you what you're leaving on the table. But with just the blanket ET, It sounds like a stock car, running averageish stock ET's.
For another comparison, I have gone 13.6's/103ish in mine (stock LT1/M6), However, it was in Vegas (2200' elevation) and it was also ~100*F. I think a healthy LT1 should go low, low 13's with MAX driving.
Can you post your entire slip with the 60' marks?
Sounds like you can shift pretty well, even so your car should run high 13s on a normal day if not heat soaked which is pretty darn good.
shot of Nos, you would be able to have fantastic times and keep cost in check est about $ 3,000.00 for all mid 11's should be reasonable with this combo.
330=6.097
1/8=9.119
MPH=81.34
1000=11.706
1/4=13.869@104.59
OP: Your car is a good runner, as indicated by your TRAP; 104.6 mph. That's a good number. The trap is very indicative of HP and is not affected much by launch, shifting, etc. So you have a good running car there. HOWEVER:
60'=2.318
That is not good, and where you might focus your efforts at a future outing. Car should 60 2.0x easily, and .1 at the 60 = >.1 at the end of the 1/4. So if you could dial that 60 down to a reasonable 2.02, you'd basically run a 13.569@104, same day, same weather. Probably even a little better than than, b/c IME, .1 @ 60' = ~.13 @ the 1/4. Anyway, I've 1.9'ed my stock car, on stock street tires, so assuming you could run that, you'd be looking at something like 13.3's - 13.4's @104 which is great.
Cliff notes: Get your driving maximized and you've got a low 13's car -just what I said it should run, above.
you have a lot of talent my friend most people with the torque these engines produce
are well over 2.20 so you have done a good job.
Given you DA at -500. I think your trap speeds should be quicker.
My Personal Best at a DA of 1470, is 13.38@almost 105. I over have 2MPH on you in the 1/8th. Same 60' time of 1.99.
Make sure you car is in top stock running condition. Fluids, plugs, wires,etc...
Get a manual fan switch, those high temps only hurt your top end.
I'd love to see what my 93 would do in -500 DA air.
As Tom has said, bone stock LT1/ZF6 cars are capable of low 13's with max driving. My car has more in it. I think at my home track I can get 13.2 with better driving. Faster than that and I need better DA. DA of 1470 is about as good as it gets at PRP.
A few and I do mean a few folks have broke into the 12's on street tires in stock trim. Mr. Mojo is one of them. He has MAX driving down and the track he is at (I think Englishtown?) is top notch and near sea level.
***Another thing, DO NOT RUN THE A/C in the staging lanes.*** At PRP that really ticks people off. The track rules forbid it. Your track maybe different, IDK. Manual switch is best.
I slowed my car down (pulled out the GM847 cam, converted LT1 intake, 3" exhaust, and 3000 stall converter) The car have 105-106 MPH now. (It lost 10-12MPH) I ran 13.1s -12.8s the last few weeks. I rebuilt the trans a few months ago, and it has a converter that stall about 1800-2000 RPMs. My 60ft are 1.8s-1.79 that's on a plain radial tire.
I was at Etown the week before last, and they had the import VS domestic, it was a few vettes there, and I was watching there ETs.
One was a 08 ZO6 it ran 13.0s @ 122 and a 05 coupe w/ exhaust and cold air induction with tune and drag radials that also gone 13.0s @112 MPH. It was 42* that day, and Etown is 70 ft above sea level. The DA was good that day, my car went 12.8s w/ 1.79 60 ft
Randy
