I'm about ready to make a last gasp and install a straight axle in my toy. With 600 rwhp and 190 more available I simply can' t put the power on the pavement running the 700R4. Others can but I can't. I've asked for gearing opinions from others and had comments ranging from 345's to 488's. If your running over 500rwhp with a 700R4 I'd appreciate your views.
Are you setting it up for drag racing? If so, 1/8 or 1/4? What are your trap speeds? There are several online calculators to help you decide what you need. IMO use a calculator and pick a gear that will allow you to trap about 200 rpm below your redline.
bTechnically your correct. However in reality it doesn't work that way.
I've been doing this for 50 years. IF you can avoid wheel spin the calculations do indeed help. However, lack of traction is the problem that causes the calculations to go out the window. I've played with various gear ratios up to and including 5:48's on the street@3mpg. Currently with the supercharged vette, 700R4, and 3:45's in the D44; traction takes place just prior to 3rd gear. Therefor would it be better to run a set of 3:23's or 3:08's. From my point of view, traction first and adjustments later. If your running an over powered Vette with a 700R4 your views are appreciated.
If youre looking for traction just run a taller tire. If you step up from a 26" to a 28" it will mimic having a 3.23 gear and provide you with a longer contact patch for more traction. Would you consider a drag radial? What tire are you running now?
Why not? What prevents it from working "in reality"?
theres also another 'school of thought' where the less 'shifts' you have with a boosted car, the better it will be because the boost is not 'wasted' between shifts.
Someone needs to come up with a no-lift-shift device.
I'm jealous of your 3.45's. Mine's over whelmed with the 3.73's. I want to run 200 mph in the mile but I can't realistically reach 180 with a 26" tire. What are you goals? If it's just controlling it, go to a 27" et street radial and it'll calm it down at that power level. If push comes to shove, get a 305 mt radial. It'll take more than you can push at it.
you need to adjust your IC so it affects your antisquat, so you can improve your traction.
you can buy altered front control arm brackets, or fab some up yourself.
