Before installing my fresh 4l60e I took some pictures for those interested in my straight axle setup. I am utilizing a torque arm similar to an F-body. The torque arm and transmission mounts are connected to a birdcage in the inside console connecting the outside framerails to a bar running in front of the seats to two bars connecting the rollbars. Unfortunately the computer storing the interior pictures died and took the pictures with it. The console now covers the birdcage. This is strong enough to support the car if a jack was placed on the mounts.
Willie, I like that setup. Do the torque arm improve the weight transfer on you car? I know that the weight distribution is 52/48 on the C4. Does it act as a lever, to help the car hook harder.
Randy
It is like a long ladder bar. My fabricator friend did spend a lot of time at the drawing board figuring out center of gravity and roll centers and other stuff I have no clue about. In the first picture shown is a zerk fitting on the bottom front of the torque arm that services a hardened sliding shaft so the arm won't bind during rear suspension movements. The reason he chose this approach is because he thought a 4 link suspension would have such short arm lengths that it would be difficult to get the weight transfer of the torque arm without chopping up the car. In essence, when the tires plant, the front of the differential wants to go up. This force is transferred to the belly of the car via the torque arm which lifts the front of the car and transfers weight to the rear tires. There are other C4s out there with 4 links that work really well, so obviously this is just one approach. Here is a picture of weight transfer.
I did not notice the slider built into it. Very cool. You have a damn good chassis guy, to make that car leave like that and go straight down the track. Impressive.
I purchased a Strange 9" with alum center for my 92. Just waiting to get it in the shop. I too have a friend who will be setting it up. As of now I am going with a Triangluated 4 link with no locator. I am hoping it will still handle well. The other option will be a Watts Linkage.
Thanks Jack. Actually, when we first set this up, it didn't have the antiroll bar. The car would roll over to the right. Got a couple of real good looks at the right wall.
Originally Posted by STEVEN13
Cool car Willie!
Wow, cool setup. Very well designed and thought out. Its neat that it is hidden inside the console. Sounds like you got a good chassis fab guy. Obviously you've been running this setup without failure and its proven.
Gotta love it.
Gotta love it.
Thanks, I broke a ring gear on the last race of the season after Thanksgiving. I won the first two rounds and then had to put the car on the trailer. 450 10 second runs on this gearset. Not bad.
Looks good , A short 4-link set will work fine they are just a bit more sensitive to adjustments . The links on my car are on the short side but i was able to pull a 1.26 60foot with my SBC .
