WHERE IS THE FAN RELAY ???
Old Jun 9, 2002 | 10:49 PM
Mile High
Mile High "91"
Default WHERE IS THE FAN RELAY ???
I recentley posted a thread titled " fan switch????" where the author 65ZO1 stated "Get a DPST switch, wire one side to ground and one of the two poles to each fan relay's Grn/Wht wire." only on more question where is the fan relay on a "91 coupe auto? :confused:
Old Jun 9, 2002 | 11:08 PM
blkc6z51's Avatar
blkc6z51
Default Re: WHERE IS THE FAN RELAY ??? (Mile High "91")
The fan relay should be the same as my 90, on the left side of
radiator. Should be 2 of them Primary and Secondary relays. :cheers:
Old Jun 9, 2002 | 11:26 PM
Mile High
Mile High "91"
I just went out to my car and sure enough both relays are there but theres no "Grn/Wht wire". On the relay closest to the front of the car there is a thick red, black/red, pink/black & light blue/black, right behind that on the second relay thick red , black/red, pink/black & blue/white. So for a double post switch I would hook one pole to ground and the other pole to what wire on my relays :confused:
Old Jun 10, 2002 | 12:04 AM
blkc6z51's Avatar
blkc6z51
If you go to http://www.madvet.com and click on (Tech) then on instruction sheets
then the part# it is 609116 this will give you the intructions with photos.
Print it out. You need to have 2 wires one to each relay and ground,
both wires go to one post and the ground go to the other.
hope that helps. :cheers: ps the wires are not green/white just use the
wire that comes from cavity F on both relays.
[Modified by blk90, 10:21 PM 6/9/2002]
Old Jun 10, 2002 | 02:55 AM
Mile High
Mile High "91"
Default Re: WHERE IS THE FAN RELAY ??? (blk90)
One last question, do I need to put a fuse in line, and if so what amprage fuse should use? Also in reference to amprage what size switch should I use? Send help soon its getting hot in the Mile High city.
[Modified by Mile High "91", 11:57 PM 6/9/2002]
Old Jun 10, 2002 | 01:34 PM
blkc6z51's Avatar
blkc6z51
You do not need a fues, I think the switch I used was 20 amp
have had it in for a year now no problems.
To WHERE IS THE FAN RELAY ???
