How much HP???
Old Dec 12, 2012 | 05:27 AM
shamdave's Avatar
shamdave
Default How much HP???
How much HP and tourque can the stock c4 drive train handle? I have a stock 1985 auto. Just cuious before i build/buy an engine?
Old Dec 12, 2012 | 06:25 AM
AirForceOne!'s Avatar
AirForceOne!
Not sure about the earlier C4's, but the 90 ZR1 came stock with 375hp and 370 lb-ft.
What transmission and rearend are you running?
Old Dec 12, 2012 | 07:43 AM
WW7's Avatar
WW7
I would think there would be to many variables to give an accurate answer... How you drive is real important, rear gear ratio, which tires you chose also figure into the calculation,.. If you have tires that hookup well it would put much more strain on the drivetrain then tires that spin easily.. When I put my 383 in my 89 I went to a stage 2 trans that would handle 500hp just so I wouldn't have to worry .. Also with slicks at the track that D36 and stock trans won't last very long with more torque....WW
Old Dec 12, 2012 | 08:22 AM
vader86's Avatar
vader86
HP never breaks things, its the torque that breaks it.
It is too ambiguous to give you a solid number where the tranny and D36 rear axle will break. These things tend to blow whenever they choose to do so.
If you hook up really well on a launch, the rear could obliterate itself with 350-400lb feet. If you put slicks on it, the thing could even blow at stock power level. It might survive 1000 1/4 mi passes or it may not last 2. Its all about the instantaneous torque delivered to a part. For 'normal' daily use the 36 would be fine for awhile however.
The 700r4 could also bite the dust whenever it wants to. Mine survived 500lbft for daily use, but I was already saving for the day when it blew, which eventually it would've had I not lost the car to the accident.
But I would say that if you plan to push over 400lbft you should already be planning a future upgrade of the tranny and D36, particularly if you race it.
Old Dec 12, 2012 | 01:27 PM
shamdave's Avatar
shamdave
Cool thanks good info, I am not sure what rear end (ehat ever was stock in 85) the trans was rebuilt a couple years ago and is a 700r4. I guess i will stick to my original plan to go about 350hp 350-375tq, that should be enough to get me in trouble
Old Dec 12, 2012 | 03:44 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Assuming you're still planning on buying a crate motor with those advertised specs, you'll be perfectly OK with your current drivetrain.
Old Dec 12, 2012 | 03:53 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
FYI
There is a limit
Old Dec 12, 2012 | 05:38 PM
shamdave's Avatar
shamdave
Originally Posted by PLRX
FYI
There is a limit
awesome! Some duct tape will fix that right up
Old Dec 12, 2012 | 06:57 PM
383vett's Avatar
383vett
I think the 36 will hold up well with street tires and an auto. It won't really matter how much hp you have, the street tires will fry before something breaks (for a while anyway). As far the stupid suggestion about taping the twisted halfshaft above, the only way that could possibly work is to make sure you swap ends so they unravel on acceleration.
Old Dec 12, 2012 | 07:07 PM
Phat98's Avatar
Phat98
I think we're in JB Weld territory here.....
Old Dec 12, 2012 | 10:29 PM
Photomania's Avatar
Photomania
FYI
There is a limit
Any idea how much torque did that? I saw something similar when a truck was hauling a large load of bricks up a steep hill to a construction site.
Old Dec 12, 2012 | 10:46 PM
cv67's Avatar
cv67
St. Jude Donor '05
Originally Posted by 383vett
I think the 36 will hold up well with street tires and an auto. It won't really matter how much hp you have, the street tires will fry before something breaks (for a while anyway). .
Wouldnt worry about it just build it drive it if something happens it happens. Might not.
Old Dec 12, 2012 | 10:51 PM
GREGGPENN's Avatar
GREGGPENN
If you didn't bump it up enough to worry about breaking something, did you really do enough?
Old Dec 13, 2012 | 08:05 AM
TA's Avatar
TA
I'm not positive, but I think that's from Vic'89's car. If not his then it's very similar to what his did at the track one day. IIRC both sides broke in the same manner on the same launch. I believe he was still running stock heads/cam at that point and was somewhere in the area of 350 ft/lbs of torque at the wheels. Vic's car has been down the track many, many times with even more power than this, so I'm sure what caused the carnage on that one particular run.
Old Dec 13, 2012 | 08:31 AM
AirForceOne!
Old Dec 14, 2012 | 02:55 AM
gerardvg's Avatar
gerardvg
On my 85 Just adding headers cold air intake and adjustable fuel pressure regulator to get 45-50 psi and knocking a second of the quarter mile time killed my trans very quickly.
However have since put a blower on and went h/d with the T700R4 rebuild i have got two or three years out of my last trans, the half shafts tend to save the trans and D36 they twist easily. Have had steel half shafts made and my D36 has put up with 8 psi boost for the last 6 years.
The blower is now boosting a new 383 so will see how it goes
If the D36 spits the dummy then i will put the D44 in
To How much HP???
