Drivers Seat removal
Old Dec 13, 2012 | 02:47 PM
keebler56's Avatar
keebler56
1st Gear
Default Drivers Seat removal
How do I remove the drivers seat from a 1986 vette. I have the Bottom cushion up and there are a bunch of wires and vaccuum hoses. do I need to disconnect the vaccum hose along with the wires. If so what about the hoses and wires that run out the back of the seat? Where do those get disconnected at? pictures or video would be helpful
Old Dec 13, 2012 | 02:55 PM
94z07fx3's Avatar
94z07fx3
With the bottom cushion off you should see four bolts 13mm IIRC.
Back those out and see what is attached to the seat frame. IIRC there is one electric connector that will then be obvious. The pump will stay with the seat frame.
Then the rails are left and have to be in the right spot to expose the nuts that hold them on. Your power seat controls should let you raise and move forward to expose the bolts.
If your power controls are inop you can disco the flex shafts from the motor and chuck them in a drill to move the rails to the point that you can remove the rails. Note at first glance the flex shafts in their rubber tubes may just look like vacuum hoses.
ETA I just noticed the model year. Of course if your power seat controls are on the seat there will be an additional connector and you will want to position the rails to expose their nuts before you remove the seat.
Old Dec 14, 2012 | 02:03 PM
DanZ51's Avatar
DanZ51
OOOw Pictures
Old Dec 14, 2012 | 06:49 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
Originally Posted by DanZ51
OOOw Pictures
Sorry for the thread hijack ... Dan, what seats are those that you installed?
Old Dec 15, 2012 | 09:59 PM
DanZ51's Avatar
DanZ51
Corbeau A4
Old Dec 16, 2012 | 01:16 AM
leesvet's Avatar
leesvet
nice......!
To Drivers Seat removal
