Hello everyone i m new to the forum has anybody ran across any deal on good opti i have a code 16.Are there any reasonable shops in my area i live in raleigh nc thanks for any help
Thanks all replies i have a est price for oem opti water pump ign coil plugs and wires parts and labor 1900.00 i think that s a bit much whats the avg price
I have a friend who has a '96. He took his car to the shop for Opti, water pump, plugs and wires, etc... and the bill was almost 2K....Basically $1000 in parts and $1000 labor
AC Delco (92-94) or Delphi (95-96) is the only way to go.
The Petri$ optisparks used to be good, but they could possibly be using other non-OEM cores that dont have the mitsubishi optical sensor. Someone had a post here about this lately with all kinds of problems on one.
Too many problems with other knock-off optisparks.
If you have a '92-94 (gen I), then this is a good deal. Note, in the pictures, the Mitsubishi emblem on the optical sensor. This is the heart of the unit. You also want to make sure the reluctor ring isnt 'warped' as it is on some knock-off units and that the bearing / seals are tight.
Im selling my OEM AC Delco unit - where I added a 'vent' to it for fresh air and a vacuum line - like the 95-96 style. Worked great, but I had to convert to gen II style to use the LT4 extreme duty timing gear.
I have pics of the optis that Petris sent to me. I was less than impressed.
from your pictures, it looks like they might have changed the 'core' unit they base theirs off -of. (to one that doesnt use mitsubishi sensor, like in my picture).
no Mitsubishi marked sensor buteverything looks new. I do not think he is using rebuilt parts. He also renegged on his lifetime warranty. Mine did not make it 5 seconds without tripping a code 16.
I just went with a used take-off that needed a new cap and rotor. The bearing may lock up tomorrow I just installed it as an experiment to see if my codes would go away. It's been running great so far!
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
And I have a Summit Racing "white box" Gen 2 Opti on mine.
Had to get one "now" because the gen 1 wouldn't work on the new motor.
So far it has a full season of road racing on it. Was cheap enough that it may even make sense to keep running it until it dies - then buy another.
I'll dig through my stuff - I may still have a gen 1 Dynaspark (just before Dynaspark was sold off).
Damn - got to get my act together and sell off some of this stuff I'll never use again.
Is this 'white box' an AC Delco 'remanufactured' gen II optispark?
Be advised, I got one of those, with a defective optical sensor (from gmpartsdirect).
You could see where they spraypainted black spraypaint over a crack on the optical sensor housing. (but did have Mitsubishi emblem).
The issue with the remanufactured optispark is that they 'recycle' the mitsubishi optical sensor from the core. Its not new. They put in new seals, cap, rotor, bearings, which is great. However the heart of the unit is not replaced.
