87 need pin #s for ECU
Old Dec 17, 2012 | 01:52 PM
The Bus's Avatar
The Bus
Default 87 need pin #s for ECU
I need to know what the pin #s are on 87 ECU. I'd like all #s if possible but really need what these two pin #s are.
Facing the ECU with the connectors on back. The smaller connector pins A11 and B2.
Thanks for all help.
Old Dec 17, 2012 | 02:00 PM
WVZR-1's Avatar
WVZR-1
I've generay relied on the infomation here if I didn't have the correct FSM.
Scroll down to 1227165
http://www.chevythunder.com/fuel%20i...ts.htm#1986-89 pinouts (ecm #1227165)
Here's Cliff's work I believe:
http://home.earthlink.net/~cliff_har...s/pinouts.html
You can compare and if there are questions see Cliff!!!!
Old Dec 17, 2012 | 04:33 PM
The Bus's Avatar
The Bus
A big thank you
Old Dec 17, 2012 | 04:50 PM
WVZR-1's Avatar
WVZR-1
A big thank you
No problem!!!
To 87 need pin #s for ECU
