Drive shaft removal help
Old Dec 18, 2012 | 11:55 PM
Blown1987's Avatar
Blown1987
Default Drive shaft removal help
Exhaust and c beam dropped i have two of the four strap bolts out but the other two won't budge without stripping. Already used some pb blaster and nothing. Any ideas?
Old Dec 19, 2012 | 12:53 AM
383vett's Avatar
383vett
If the heads are stripped, you have no choice but to grind down the heads with a die grinder to remove the strap.
Old Dec 19, 2012 | 01:28 AM
Blown1987's Avatar
Blown1987
That's what i was afraid of. What do i do if that's the case?
Old Dec 19, 2012 | 02:15 AM
WVZR-1's Avatar
WVZR-1
1 on each strap or 2 on one strap? Did you soak them again before walking away?
Old Dec 19, 2012 | 06:24 AM
John Robinson's Avatar
John Robinson
You might get a set of these bolt extractors
http://www.irwin.com/tools/screw-bol...-grip-base-set
I got mine at Advance Auto. They grip so tight that I bent a 3/8' break over bar the first time I used one. Keep soaking the bolt in PB blaster until you get a set of these.
Old Dec 19, 2012 | 07:48 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Did you apply heat? A bottle torch will be a big help. Heat the yoke, not the bolt, once you get it good & hot "shock" it with some PB blaster. Also cuisinartvette posted a formula for some penetrating oil that is said to be far superior to PB. It's a 50/50 mix of ATF & acetone. Maybe give this stuff a try before grinding but DO NOT use the torch with it! If the head of the bolt is too rounded off try taking an old socket a bit smaller and beat it on to the head of the bolt.
Old Dec 19, 2012 | 07:50 AM
Midnight 85
Craftsman also has these & they really do work but I really don't think there is sufficient clearance to get one on the bolt.
Old Dec 19, 2012 | 08:48 AM
LD85's Avatar
LD85
Put a piece of steel on top of the bolt head, like a dowel punch etc, and give the bolt a smack with a HEAVY hammer (BFH), then see if that cracks it loose.
To Drive shaft removal help
