Need to replace a headlight
Old Dec 20, 2012 | 11:50 AM
Psychored's Avatar
Psychored
Default Need to replace a headlight
But I need to know how it's done! 89 Coupe. Thx
Old Dec 20, 2012 | 12:51 PM
Red89'-L98's Avatar
Red89'-L98
FL Events Coordinator
St. Jude Donor'13
Take off the bezel, it should be 4 screws. It is bezel that you see when the headlights are open.
Then there is a chrome colored headlight retainer ring that holds the headlight in just unscrew it and you are then at the headlight.
Just pull the headlight out and undo the plugin for it and plug the new one in and reverse the procedure to put it back together.
Old Dec 21, 2012 | 11:10 PM
Photomania's Avatar
Photomania
There should be some screws for adjusting the height of the beam. When I replaced my headlights with the brightest that the auto parts store had, I took the 1990 coupe out on a dark, desolate road and got the screw driver out and adjusted the beams.
Old Dec 22, 2012 | 09:34 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
It might be slightly different for your '89, but probably close.
http://forums.corvetteforum.com/c4-t...eadlights.html
To Need to replace a headlight
