how close to the timing cover should the flywheel of the harmonic balancer be?
conversly, how far on the crankshaft? end of crank shaft flush with end of balancer?
I am using the proper tool from advance auto and it was going on fine, then bam...hard as a rock. I can't turn it without a TON of force. and I'm afraid of stripping out crankshaft.
[QUOTE=The Plastic Lizard;1582625832]how close to the timing cover should the flywheel of the harmonic balancer be?
so looking for some guidence.
The proper torque spec on that dampener (balancer) is 60 ft-lbs, if it takes more then that to get the dampener seated in the proper position, you may have other issues that you need to address. Is this the original dampener or after market (size difference)? Gouges on the crankshaft or internal bore of the dampener. And leave the hammer in the tool box.
When you knock the rubber seal loose from the balancer and then your your crank vibrates and you spin a bearing, you will then learn why there are some applications that don't call for the use of a hammer. Why don't you get a pulley install tool and do it right?
From: Supreme Soviet Peace-Loving Pipple's Kollektive of Seattle Wa
FWIW and considering what's at stake, I'd pull the dampener and using a piece of welding rod or something similar, record the length of the crank snout from the crank gear face to the end and record the length of the dampener tunnel. Those will tell you when you've butted up to the gear.
Check your key like someone said, for alignment and even-depth.
I use a longer bolt with the thick flat washer first, also i put some wd40 on the balancer before fitting it, then put the correct bolt in to get the balancer home all the way. Just hold your crank pulley up against the balancer and see how it lines up with the water pump pulley.
what year engine? I only ask because on a 96 the reluctor ring could dislodge from the shoulder of the key that it sits on, and then there would be all sorts of mischief to pay.
by the way I agree, if the balancer stopped suddenly; its probably on.
Look at the picture in post 7. That's what it looked like when stopped. I confirmed this by installing the water pump and everything lined up perfectly. I strongly suggest getting the install tool from the auto parts store. It doesn't cost anything at the stores here to borrow the tool for a couple days.
