Blowing the fuel pump fuse
We recently had to replace the fuel pump on the 86 and decided to go with the Racetronicx pump kit (not wiring harness) with the 255lpr pump. The after a bit of back-and-forth with Racetronicx, we got a working pump but now we've blown the 10amp FP fuse twice in 30 miles.
Does anyone know if this pump is supposed to draw significantly more current that the stock pump or have any ideas where to look for problems?
Thanks!
being a larger more productive motor that pushes a LOT more fuel, that increases the resistence thus making the pump draw more amperage,.yeah, it most likely needs to go up in the fuse size. I would NOT do anything until I spoke to Racetronix and verified the fuse required for that pump model. Until then I would go thru the wire harness and fuel relay to be sure there are no bad wires or shorts.
http://www.racetronix.biz/itemdesc.a...WH-013&eq=&Tp=
" The C4's factory fuel pump power circuit was designed to provide power for the light current
demands of a factory pump. . Current demands can more than double when a high-performance fuel pump is installed.... Starving a pump for voltage will cause it to slow down which escalates current demands even more thereby
compounding the problem..
Just because the factory wiring to your pump is convenient think twice about cramming a 20 amp fuse in !"
