so i figured out through research the 1441 code means the evap system isnt working correctly. so i looked up the parts in the system. seems to me like theres a solenoid, a valve, and a canister. along with all the rubber lines connecting them. is it just me or do all these parts seem to have the same name? like the solenoid for instance is called a canister purge valve solenoid, but theres a different part for the actual valve? im very confused but here's wwhat i have so far off rock auto.
just seems like there all called different things depending on where your looking. are these part numbers correct? there are pictures but one picture of the valve looks like a picture of the solenoid and one pic of the canister looks like a valve etc...
also anyone know where i can get the rubber lines? thanks
