C4 Offset Clutch Throwout Bearing? Help!
Old Dec 28, 2012 | 06:34 PM
kccampro's Avatar
kccampro
Cruising
Default C4 Offset Clutch Throwout Bearing? Help!
Hey there... I'm new to the forum. I'm in the process of installing a SBC into an old Porsche 928 using a C4 clutch set-up. Just a quick question for you C4 guys - have you ever seen an offset throw out bearing? I have ordered two of them and they both look the same way. These bearings look like they going to wear against the pressure plate fingers. I can't figure out if they are both defective or if there is some mechanical reason for them to be offset. Both bearings are for C4 corvette. Picture attached with measurements for reference. Theories and opinions welcomed. Thanks, Bill
Old Dec 28, 2012 | 07:45 PM
kccampro's Avatar
kccampro
Cruising
Self aligning throw out bearing... Looks like I found my answer on the RAM clutch technical page.
Old Dec 29, 2012 | 08:29 PM
mtwoolford's Avatar
mtwoolford
love thinking out side the box.
"Both bearings are for the C4 Corvettes"
don't know if this is of help, but as to the pull type clutches used 92 to through 96, the earlier "black tag" ZF trans/ clutch combo's used a throw out bearing with a larger I.D. than the late "blue tag" combo's did; mixups here are common.
Old Dec 30, 2012 | 06:00 PM
dizwiz24's Avatar
dizwiz24
Also be aware that oem quality throwout bearings are near impossible to find.
The newer throwout bearings are made in china and are sloppy with lots of off axis play in them.
Its very frustrating
Old Dec 31, 2012 | 12:40 PM
kccampro's Avatar
kccampro
Cruising
Thanks!
Old Jan 2, 2013 | 07:16 PM
dizwiz24's Avatar
dizwiz24
btw:
the TO bearing you post in that above picture looks nothing like the TO bearing in the corvette
heres a throwout bearing for a ZF black tag (89 thru half of 93)
Even the chinese ones 'mimic' the overall shape/construction of this one. They just arent as tight (sloppy with more off-axis play between the parts)
Old Jan 2, 2013 | 07:50 PM
WVZR-1's Avatar
WVZR-1
btw:
The bearing he asked about is for everything through '88MY - there's likely very few that understood the offset he mentioned. A very observant tech!
To C4 Offset Clutch Throwout Bearing? Help!
