Braided Steal Brake Lines
Old Jun 11, 2002 | 10:03 AM
Dolfan's Avatar
Dolfan
Default Braided Steal Brake Lines
I am considering adding the steal lines to me '89 as I give the brakes a once over in the next weeks. I've been autocrossing and want as much brake as possible for the stock class. Are the places like Ecklers and Zip on target with their price of about $120 for a set of 4? What are the chances of picking up something like these locally at a NAPA? cost? Any other tips on these lines?
Just curious before I order.
Old Jun 11, 2002 | 10:26 AM
vader86's Avatar
vader86
Default Re: Braided Steal Brake Lines (Dolfan)
I would get the ones from VetteBrakes & Products, but as long as you get them teflon-lined there shouldnt be a problem.
Old Jun 11, 2002 | 10:36 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Give Summit a call and check out their Russell brake lines.
Old Jun 11, 2002 | 12:21 PM
LD85's Avatar
LD85
Default Re: Braided Steal Brake Lines (65Z01)
Hey Dolfan you stole the handle i wanted to use! :cry
Old Jun 11, 2002 | 12:36 PM
Dolfan's Avatar
Dolfan
Default Re: Braided Steal Brake Lines (ld85)
I found the lines for about $95 at summit, so that sounds pretty good. What about pads and upgraded fuild? I have heard quite a bit of bad news about the Hawks pads, what others seem to have good results with stock calipers and rotors. Dust isn't my biggest worry.
Id85, sorry about the handle.
Old Jun 11, 2002 | 01:08 PM
65Z01's Avatar
65Z01
I just put a set of Raybestos PG Plus semi-metallic pads (P/N PGD413M) on the rear; so far so good.
To Braided Steal Brake Lines
