Well my Callaway project runs, but leaks oil. I purchased some pre make oil lines from a local speed shop; I assumed premade meant bolt on.....but the leaks are coming from the oil fittings.
I assume this is not normal....should I have tightened the fitting before the banjo connection, seems to me it should not have play:
shouldn't leak. is it leaking from where the hose enters the fitting or from the banjo seals? premade is usually tight and ready to use in my experience, but I make my own generally so its been a while.
I have had old/bad gasket rings leak on banjo fittings and also make sure the banjo bolt and banjo housing are designed to work with each other and also that the banjo bolt is not bottoming out before it clenches the housing.
the fittings from the line to the banjo were not tight, I guess my inexperience in working with other than stock parts.....1 down 2 more to go
At least they are easy to get to right? lol probably not as it would happen to me... well at least you know how to fix the leak then report back with some impressions of the car.. It looks great!
