I know lot's people say it's not so but this C-4 96 LT-4 ( the way I have it set up ) will on any day run curve to curve with a stock C-5 Z06 with 15 year old bushings ,can't pass the ZO-6 more power but curve to curve it's on..and it not the way it came but NOS just the same..I may have found some rubber from GM I got inside info will check it out.. No squeake.. I'm not takem apart to grease . I think I can beat the SYSTEM so far I did what most say could not be done,take an old C-4 and run the the big dogs .. There faces in the rear view mirror ..PRICELESS... Thanks for the input and if and I have to go with poly might have to, will use your help on the install...Thanks for your time..
Yes. You want to avoid having to compress the poly body when putting the dog bone into the trailing arm brackets on the frame.
Try some prunes for the other thing.
I would imagine it's best to tourqe the bolts untill you fell some resistance on the joint and not worry about factory tourqe specs?
What's the best way to add grease fiitings i.e. drill sizes and where do you place your hole? Are you inserting grease between the poly and metal bushing or inside the metal bushing and through bolt?
I actually would use the factory torque specs. At that torque you'll want a nice smooth rotation of the trialing arm. So you may have to shave the shoulder of the bushing until that happens.
I never had grease fittings on mine since I could never find a good place to put them and have easy access. I just greased the bolt hole in the metal sleeve and the face of the bushing shoulder that will contact the frame bracket. In the other areas I preferred to have the poly tight to the dog bone and the metal liner tight to the poly.
Double-check those dog bones in that '96 before you start pressing bushings out/in...they're composite, not metal like the earlier ones. They probably aren't partial to being pressed on.
Update: After reading all the input on the polly Etc. and not finding any rubber ..Could have got some new rear control arms with rubber but had the polly bushings already..I had composite control arms ,the VBP bushings I had will not fit them called asked said no will not work .. Had to buy all Alum. ones ,wasen't a bad install ???? Strate line way better, curves?? I will know more this weekend going to the track..It's way stiffer for sure.. Have some pic at radar502 base LT-4 garage.. This wasen't my deal but thanks for the input. It's a big help to have people talking about what they did to there rides likes and dislikes about parts they have installed ..Now I am going to get a back brace...
As someone that has had the stock bushings (In hindsight I messed up when replaced them with Poly when they were still good for a performance improvement) , Poly bushings and spherical rod ends.
I have to say I would never install poly bushings into the rear of a C4 corvette again. The ride was stiff and I equated that with better handling, however, since my spherical rod end install I found out I WAS WRONG. The spherical rod ends made the ride much more compliant and improved the cars handling. My wife likes riding in the vette once again (for 5 years she hated riding in the vette. I love how much better it feels going around corners.
So if you want a stiff ride go poly, want to improve your handling go spherical rod end and retain a comfortable compliant ride quality.
