Cleaning A/C condenser
Old Jun 11, 2002 | 12:09 PM
Frodo's Avatar
Frodo
Default Cleaning A/C condenser
I have a '89 coupe and I'm in the process of cleaning my radiator and condenser area. I have the radiator out now. That part was easy. As I look through the condenser fins I see lots of fine particles stuck in there. My question is how do I clean out between the fins? I don't want to remove the condenser since that requires an A/C teardown. My car is in the garage where I work on it so I can't just hose it out. I've tried compressed air but it doesn't seem to work very well. Since the radiator is out, and the automatic transmission cooling lines are disconnected, I can't drive it into the yard without losing lots of trans. fluid. Anyone have a suggestion? Thanks in advance!
Save the Wave!! :seeya
Old Jun 11, 2002 | 01:45 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Re: Cleaning A/C condenser (Frodo)
Put the car in neutral, let it coast out, then blast away on the condenser with a pressure washer? You can bolt your radiator back in, refill, burp and button it all down again later. Just a thought.
[Modified by onedef92, 12:46 PM 6/11/2002]
Old Jun 11, 2002 | 02:15 PM
ZylaRace's Avatar
ZylaRace
Default Re: Cleaning A/C condenser (onedef92)
B4 you hit it w/ pressure washer go down to the parts store and buy a new one. You will need it when you are done.
They make a "fin comb" to straighten the fins of a condensor. This will also remove the dried bugs and road debris.
You can hit it w/ soap n water w/ a dust pan brush to get the surface dirt off,.. but that is getting a little ****.
Old Jun 11, 2002 | 10:32 PM
1-MORTOY's Avatar
1-MORTOY
Connect the trans lines together with a short piece of rubber tubing and gearclamps. Maybe you can do the same thing with the rad hoses,connect them together with a solid wall pipe and gearclamps. Just a thought, it might work.
[Modified by 1-MORTOY, 8:33 PM 6/11/2002]
To Cleaning A/C condenser
