84 Corvette performance questions
Two centsin. I had an 84 and did some moddds and was satisfied with it.Had it for nine years. First I put an 85 Fuelpump Bosh platinum plugs Accell Ignition under drive pullys A I R pump eliminate it 160 thermostat elininate CAT muffler elininators allminum radiator K&N filter A D S chip {no longer made}and BEST was a HOMEMADE RAM AIR setup. In front of the radiator the soid plastc CUT a hole with a dremel to MATch the hole in the HOOD . Mine worked likea vacumcleaner I had to put a screen under the front air dam it was sucking air so good. I added a T C I shiftkit . I tell you it was real good I could smoke the tire at will Try it I did this little at a time there is a CRoSSFIRE website I was on
OR go drive it above 30 mph to re-set/bottom the IAC motors. It would an amazing coincidence if a problem arose after valve cover gaskets...that was unrelated to the R&R'ing of the valve covers.
EDIT: How do you know the intake has been ported. I'd be shocked if it were completely/FULLY ported. I'd guess that it's "port matched" which only shows you about 1/2 the benefit.
does it look like this?
www.camaros.org/crossram.shtml
What's the general consensus on the swirl plate in the intake cover? I opened up my throttle bodies and machined out the ports but I left these diverters alone.
What are pros and cons?
"Pros": Better Airflow. Unmeasured, and unsubstantiated, but reason says that nothing in the way flows better than something in the way.
"Cons": Poor fuel distribution and puddling on the plenum floor. Now read on...
There isn't a "General Consensus". There are some who left them, some who modded them, and some who removed them entirely. I think that each person feels that what they did, was the best way. No one that I know of has done back-to-back testing on just that one item, so in reality, we don't know what way is "best".
Here is MY .02; I removed them completely. I "get" that they're in there for better fuel distribution. However, with mine removed my plugs read about the same as stock, I still got 24+mpg (Better than stock) and it idled like stock (even with a 224/234 cam -in a 400). So was I "missing out" on distribution? I don't think so. Not in any meaningful way. Again, realize that GM had to meet criteria that we don't have to and don't care about (emissions criteria, mostly).
What I did was radius the underside of the lid and take that up into the TB's a little -like an upside down "velocity stack". Idea here was to slow the A/F mix as it enters the plenum and allow it to spread. If you simply remove the swirl plate assy, the straight diameter "tube" that is the TB bore and plenum TB hole fairly shoots the A/F mix at the floor of the intake. And even more stupid, IMO, is how the swirl plate assy itself, extends the "TB bore" down another 1/2" into the plenum! My way allows the A/F mix to start spreading and migrating toward the various runners. 3/4" to an inch higher up than the stock location at the swirl blades did. Anyway, does my idea work? The numbers seem to say so. Here is a pic:
^After grinding on it with a die grinder, I smoothed my work with a brake hone and it came out pretty good, I think. I think this is the "best" b/c it offers zero restriction, and I saw no meaningful degradation in drivability or fuel economy from the removal.
Another idea that I saw that I liked was leaving the plates in, but cutting out ~98% of the diameter of the "tube" part of the swirl plate assy, so what was left were tiny, skinny tabs hanging down to hold the "fan blades" in place. You could even combine that philosophy, with my philosophy of the radius.
I also used a plenum spacer increasing plenum size and softening the radius required for the air/fuel flow entering the runners. I used injector spacers for similar reasons.
Of course the runner "roof" was also cut back 1/2-3/4".
Rather than porting the runners, I had the manifold Extrude Hone'd but didn't eliminate the EGR channel.
Mine needed a little "manual throttle"...when it was below 10*F on a cold morning starts. Needed that for about 30 seconds, then, it was fine. So not a meaningful "problem" in MY case, but as we can see, results vary.I also tried a plenum lid spacer, but in my case, it didn't help in any measurable way...but did add vacuum leaks so I go rid of it. I did like the IDEA of getting the lid/TB's up higher...just didn't work out for me. I used plastic which wasn't good. Aluminum would have worked a lot better.
