Crossfire conversion
Old Jan 5, 2013 | 03:02 AM
zodom's Avatar
zodom
Default Crossfire conversion
Just a quick question for whoever has done it. How had is it to convert the crossfire to a TPI setup while still staying rather cheap or would it just be cheaper to swap the engine for an LT or LS? I would really love to hear from the guys that have done this. Thanks
Old Jan 5, 2013 | 11:05 AM
ex-x-fire's Avatar
ex-x-fire
The mechancals is the easy part, the wiring is the hard part. If I was gonna get rid of the cfi/ecm on my car, I'd go w/ a stand alone efi wiring harness.
Old Jan 5, 2013 | 11:40 AM
JackDidley's Avatar
JackDidley
I think QWS said it was pretty easy. May be wrong though.
Old Jan 5, 2013 | 12:23 PM
Muffin's Avatar
Muffin
I am sure there is a wiring harness out there to do this swap. I also am sure that for a few dollars more a better Engine Management System can be had.
Old Jan 5, 2013 | 12:45 PM
383vett's Avatar
383vett
I went with a stand alone Accel DFI
Old Jan 5, 2013 | 01:30 PM
nutz4c4's Avatar
nutz4c4
It was fairly easy for him...He put a pretty good thread on it..Pics too
Old Jan 5, 2013 | 01:36 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
TPI is a lot of work and $$ to end up power wise where you would have with a ported stock intake and a little tuning. IF you decide to go through the effort to swap to a different style intake, please choose an intake system that provides you with better power potential than the CFI system can offer.
Old Jan 5, 2013 | 02:35 PM
zodom's Avatar
zodom
Ive found a few stand alone systems out there but no wiring harness as of yet. It just seems to be a hard engine system to figure out for me. I understand the fuel injection more than anything plus there are more aftermarket parts for it. Just tossing around some ideas for now.
Old Jan 7, 2013 | 04:16 PM
Rohn's Avatar
Rohn
Painless sells a engine to ECU only harness I recall.
Old Jan 7, 2013 | 04:50 PM
qws's Avatar
qws
Its very easy to do plus they're are no major wiring changes to do, no need to change your wiring harness. The key is the ecm from dynamicefi. As far as intakes don't waste your time with TPI.
http://forums.corvetteforum.com/c4-t...fi-to-hsr.html
Old Jan 8, 2013 | 06:54 PM
LastC3AZ's Avatar
LastC3AZ
not certain why you would want to spend the time and money for little or no gain ..... If you're looking to improve performance, save your nickels for an upgrade cam and heads ..... that alone will livin up your motor a bit .... after some intake work as discussed in the other tread that is ......
and of course not knowing for certain what you're exactly looking for, we're all kinda shootin in the dark .....
just a couple of cents worth .....
Old Jan 25, 2013 | 09:40 PM
roydettmer's Avatar
roydettmer
I did the conversion on my 84 a few years back with a speed density painless harness and computer.The real pain came when I had to change out the serpentine drive system out to the tpi motor type because the belt on a cross fire drive sysyem runs right across the throttle body.
Old Jan 25, 2013 | 11:28 PM
Dominic Sorresso's Avatar
Dominic Sorresso
I would go from CFI to MiniRam. Do the hot cam set up with better heads.
To Crossfire conversion
