1992 Corvette convertible
Old Jan 7, 2013 | 12:51 PM
Sjmt's Avatar
Sjmt
2nd Gear
Default 1992 Corvette convertible
I've owned this corvette for about 5 years and it only has 40k miles on it. Need to change over the A/C unit to the proper freon. Any thoughts on easy this is to accomplish. Please note I am not a very mechanical guy but if it is not to difficult and I can save some bucks, I am willing.
Old Jan 7, 2013 | 01:28 PM
87C4_4spd's Avatar
87C4_4spd
I had a shop convert my 87 for about $200.00. They just changed the refrigerant and connectors but it worked fine.
Old Jan 7, 2013 | 02:27 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
I'm not an AC guy, but from what I understand, there's more to it than that if you want it done properly.
Old Jan 8, 2013 | 07:56 PM
j-wireman's Avatar
j-wireman
From what I've learned about this R12-to-R134a conversion is this:
1. The oil that is used in an R12 system is not compatible with R134a.
2. No amount of flushing will get all of the R12 oil out of the system, resulting in the destruction of the R134a, eventually.
3. A couple of things need to be replaced. I think they are the pressure switch and the Schraeder valve. There could be more than that.
My suggestions are:
A. Maintain your current stock system and continue to use R12.
B. Install a whole new, clean system and fill it with R134a and the proper oil.
C. Fill with another refrigerant that is compatible with your existing R12 oil.
To 1992 Corvette convertible
