1985 Corvette Rough Idle
Old Jan 10, 2013 | 11:02 PM
kilich's Avatar
kilich
Default 1985 Corvette Rough Idle
Ive only had the car three days now and it started to have a rough idle, Idk what it could be someone told me its cause im using normal 86 unleaded fuel, They told me to use 93 and it wont do that, but its pinging right now. All stock. 101k miles, Automatic transmission. It has stalled on my twice so far. Suggestions and Advice is Appreciated.
Old Jan 10, 2013 | 11:52 PM
powerpigz-51's Avatar
powerpigz-51
check engine light? codes?
Old Jan 10, 2013 | 11:54 PM
kilich's Avatar
kilich
No light, No codes..
Old Jan 10, 2013 | 11:58 PM
powerpigz-51
Hmmm.....this screams fuel pressure test to start.
Old Jan 11, 2013 | 12:03 AM
kilich's Avatar
kilich
Ill get a Gauge and test it tomorrow. If its not the fuel pressure what else could it be?
Old Jan 11, 2013 | 12:14 AM
popo8's Avatar
popo8
Def start with the FP... but I want you to know... I fueled up with 87 octane in my 85.... and that was a full tank worth of pinging and even some smoke under hard throttle...
93 in the next tank... right back to normal!
Old Jan 11, 2013 | 12:16 AM
powerpigz-51
Fuel pump, fuel filter, air filter, plug wires, plugs, distributor cap, timing, failing sensors, bad maf, bad relays, vacuum leaks, loose wires...big list.
Old Jan 11, 2013 | 12:20 AM
kilich's Avatar
kilich
Ill try 93 tomorrow with some injector cleaner and or seafoam. Im almost on E now so ill fill up with 93 and check fuel pressure
Old Jan 11, 2013 | 09:02 AM
tunedport85inject's Avatar
tunedport85inject
i bet fuel pressure/filter.A new set of spark plugs,injectors cleaning is good as seafoaming,just a good tune up and you'r on the road again
To 1985 Corvette Rough Idle
