Initial mods for a stock 89
Old Jun 12, 2002 | 10:27 AM
Raskell5's Avatar
Raskell5
Default Initial mods for a stock 89
Could anyone help me out with an initial mod upgrade for a stock 89 with 65k miles. I don't want to go crazy yet, just want an affordable way to add horsepower, other than K+N air filter and such. :chevy
Old Jun 12, 2002 | 11:32 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Initial mods for a stock 89 (Raskell5)
Check out the mods list on my site; I'm sending you some '90 L98 mods results data.
BTW, you might consider an SLP ram/cold air intake instead of a K&N and cut lid as the kit comes with a stock size K&N, which makes it very reasonable cost wise.
Old Jun 12, 2002 | 06:15 PM
tpivette89's Avatar
tpivette89
with nothing more than a K&N with an opened stock lid, an adjustable fuel pressure regulator, and a catback exhaust system, i was able to go 13.44 at 102.51mph. this was done with 20psi in the rear tires, 6* base timing, fuel pressure set at 48 psi, and a excellent launch on street tires. i would really recommend you get exhaust first, as the factory system is very restrictive
Old Jun 12, 2002 | 06:20 PM
4GTABODT's Avatar
4GTABODT
From: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
Underdrive pulley's always give you a good bang for your buck... :cheers:
Old Jun 13, 2002 | 12:53 AM
Raskell5's Avatar
Raskell5
Default Re: Initial mods for a stock 89 (Quik86)
Thanks everyone for your replies. :cheers:
Old Jun 13, 2002 | 01:40 AM
vader86's Avatar
vader86
I dont like the Underdrive pulleys, but you should definitely go with whatever 65Z01 sent you, he knows alot about L98s.
Old Jun 13, 2002 | 12:27 PM
NavyVet's Avatar
NavyVet
I think that Gordon Killebrew has done presentations (i.e., Carlisle) where he said the most performance increase for the buck on an L98 Corvette is to replace the front y-pipe with one that eliminates the precats. Subsequently, replacing the stock cat with a high flow cat should make a signfiicant additional improvement. Good luck.
Old Jun 13, 2002 | 05:47 PM
tpivette89's Avatar
tpivette89
Default Re: Initial mods for a stock 89 (NavyVet)
this mod is what i want to do next, but with all the bad reviews about the quality of the MAD front ypipe (they seem to be the only company that makes a replacement one without the precats), im hesitating to get one. i guess ill have to find a independant shop with the skill to custom make one
Old Jun 13, 2002 | 06:57 PM
VetBoy89's Avatar
VetBoy89
I got the kit from Ecklers, front y-pipe with no pre-cats and the high flow CAT, for $250. I noticed a big difference in performance and you can't beat the price.
Now I just gotta figure out how to fool the SMOG inspector :lol:
Old Jun 13, 2002 | 07:34 PM
Vette9d1's Avatar
Vette9d1
Default Re: Initial mods for a stock 89 (VetBoy89)
Does the car sound better with the new y-pipe in place?
Old Jun 13, 2002 | 07:36 PM
Vic'89's Avatar
Vic'89
Check my signature for a list of mods that work.
Vic
Old Jun 13, 2002 | 07:47 PM
65Z01's Avatar
65Z01
Default Re: Initial mods for a stock 89 (tpivette89)
tpivette89, if you're not too far from Trenton, NJ give Denny at Mufflex a call. He did all my exhaust mods, including the custom front Y-pipe, in about 3hrs for a great price.
Old Jun 14, 2002 | 06:18 AM
pablocruise's Avatar
pablocruise
all the free mods first.
Then I vote for allowing that L98 to breathe better. No need to sink lots of money into a fancy aftermarket exhaust set-up. A killer system can be fabbed up very affordably by a competent shop. The MAD catless front Y true dual system mentioned above IS a great kit and cheap to boot if doing your own work.
Also another vote for 6* on the timing.
maybe lighten the car a little; remove spare tire and jack.
IMHO, the AFPR can wait till ya get some serious mods. Not really necessary to add more fuel to an already rich running motor.
Old Jun 14, 2002 | 09:49 AM
GRX's Avatar
GRX
Default Re: Initial mods for a stock 89 (89 Paul in Cal)
Paul, what are the numbers on your cam? Are you ok with the smog *****?
Power? IDLE?
[Modified by GRX, 5:50 AM 6/14/2002]
To Initial mods for a stock 89
