Rocker change on LT1
Old Jun 12, 2002 | 10:52 AM
T1Kilr's Avatar
T1Kilr
Default Rocker change on LT1
What performance gains would I see by changing the rockers on my stock LT-1 to 1.6 rollers?
TIA
:cheers:
Old Jun 12, 2002 | 01:57 PM
James94LT1's Avatar
James94LT1
Default Re: Rocker change on LT1 (T1Kilr)
I changed mine and added an adjustable fpr turned FP down to 39psi and
the combo picked up 3th's in the 1/4. Those were with Comp roller tip 1.6's, I am going to upgrade to a full roller soon. So maybe you could get a little more due to less friction on a full roller. But I was very happy with the combo I did! :cheers:
Old Jun 12, 2002 | 03:10 PM
jpee's Avatar
jpee
Default Re: Rocker change on LT1 (James94LT1)
I ran 12.48 with the stock rockers, & went to the GM 1.6 RR & springs from the LT4.. and I picked up .2 tenths.. in EXACTLY the same weather.. 12.28
Old Jun 12, 2002 | 03:43 PM
T1Kilr's Avatar
T1Kilr
Default Re: Rocker change on LT1 (Red96Coupe)
Did you have any problems with too much lift/ piston clearance? Were there any ill-effects from this mod?
[Modified by T1Kilr, 2:43 PM 6/12/2002]
Old Jun 12, 2002 | 05:50 PM
jpee's Avatar
jpee
NO... I just installed the new rockers, & springs.. also had to cut the drip tabs off the valve covers... but no prob w/valve clearence.. Be sure to use the correct springs..
Old Jun 12, 2002 | 09:51 PM
STL94LT1's Avatar
STL94LT1
I just did this upgrade two weeks ago, and the engine sure does rev smoooooooooth.
Old Jun 13, 2002 | 03:08 AM
GlockLT4's Avatar
GlockLT4
What's a 3th ??? :confused: :confused: :p: :jester
Old Jun 13, 2002 | 04:49 AM
FordNoMore!'s Avatar
FordNoMore!
Default Re: Rocker change on LT1 (Glock'94)
Well I have Heard from Chevy Tech reps that a stock LT1 will need the 1.5 ratio rockers for safe and optimal valve clearance and peformance gains,If Ya got ported Heads or HP heads ,well then the ratio changes,springs and rockers will change then,but as far as stock goes...1.5...... :chevy :cheers:
Old Jun 13, 2002 | 05:53 AM
93 ragtop's Avatar
93 ragtop
Default Re: Rocker change on LT1 (FordNoMore!)
The 96, LT4 came from the factory with 1.6 rockers.
Old Jun 13, 2002 | 06:49 AM
Half Fast's Avatar
Half Fast
:bs :nono: :bs :p:
Not true. Use self aligning rockers or use hardened pushrods and guideplates with non-self aligning rockers. CC pro magnums are the best for the cost.
Like Red96 said you'll have to trim the drip tabs in the valve covers. Going to 1.6 just gives a little more lift to the cam, not anywhere near enough to cause interference with a stock cam. It's an excellent mod if the LT1 is already breathing well and has headers or less restrictive exhaust. You will see gains.
Old Jun 13, 2002 | 11:14 AM
T1Kilr's Avatar
T1Kilr
Default Re: Rocker change on LT1 (Half Fast)
Ok, it seems to be a simple mod, that should work with my exaust (no cats, bought it that way) How difficult is it to do with the heads on the car? Any special tools that I would need? Any PROM changes required or different fuel pressure?
Old Jun 13, 2002 | 11:39 AM
James94LT1's Avatar
James94LT1
Thought faster than I typed I guess, 3/10ths.
Old Jun 13, 2002 | 11:50 AM
GlockLT4's Avatar
GlockLT4
:jester
Old Jun 13, 2002 | 10:17 PM
STL94LT1's Avatar
STL94LT1
It's not that difficult to do with the heads on the car, just a little time consuming.
The only special tool I needed was a valve spring compresser. I used a loaner from Autozone. However, if you have access to another valve spring compresser get it, the one from AZ is a piece of crap.
To Rocker change on LT1
