crazy MAF question
Old Jun 12, 2002 | 12:53 PM
LayZ's Avatar
LayZ
Default crazy MAF question
Ok if the car idles ok but i get, i believe, codes 32-33 could i just replace the sensors and be fine? Or go with a new one?
Old Jun 12, 2002 | 01:13 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Default Re: crazy MAF question (LayZ)
You had best explain this again.
:confused:
Old Jun 12, 2002 | 01:18 PM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Do you have a vacuum leak?
Old Jun 12, 2002 | 05:26 PM
LayZ's Avatar
LayZ
Default Re: crazy MAF question (PeteL)
I checked the vaccum lines and they look good i didnt feel any cracks. I keep getting error codes i think, i have them at home not at work, 32-33 which is MAF burn off circuit and some other MAF code. IF i replace the circuit instead of the MAF will it run better without actually buying a new MAF. Hope that helps it's hard to type and look over your shoulder at work.
Old Jun 12, 2002 | 06:24 PM
War Machine
Code 32 is EGR. I get that with code 33 and/or 34 sometimes.
My 87 gets code crazy on me at least twice a year. If it happens enough you tend to come up with a plan and here's mine...:eek: I'll disconnect the battery, unplug and clean the contacts of the MAF and the 2 relays. Plug 'em back in, connect the battery and look for codes. If I get the code 33 again the I disconnect the battery, unplug the MAF, replace the relays, the plug and reconnect the battery. It's like tricking the computer that all new sensors are being added.
I found out early in ownership about this finicky phenomenon when I messed up a new MAF by not replacing the relays with it. Or am I just crazy? :yesnod: :lol: :lol:
[Modified by War Machine, 4:25 PM 6/12/2002]
To crazy MAF question
