Dumb question-Performance axle option
Old Jun 12, 2002 | 01:15 PM
razor199's Avatar
razor199
Default Dumb question-Performance axle option
Can somebody please explain what the performance axle option is and its impact if any on actual performance.
Old Jun 12, 2002 | 01:20 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default Re: Dumb question-Performance axle option (razor199)
It is a change in your diff gear.. For the auto's the standard was a 2.59 gear (at least in 92) and the performance axle had a 3.07 gear. And yes, the higher the diff gear, the better your acceleration, but you loose some top end, and some gas milage.
-Mark
Old Jun 12, 2002 | 03:26 PM
jpee's Avatar
jpee
Default Re: Dumb question-Performance axle option (MarkLT1)
-Mark
Yes you will lose some gas milage, but NOT top end.. in fact if that were true a 6 speed would have a higher top speed in 6th but it will go faster in 5th..
Same with an auto.. with 2.59 you will never get to the RED line.. however if you get the 3.07 I think you will actually get a higher top speed.. but as you say less gas milage..
If you base top speed on that theory a rear of 1.59 would have even a higher top speed,,, The only way a 2.59 geard car would have a higher top speed than a 3.07 is if the 2.59 car had a hellova lot more HP
Old Jun 12, 2002 | 04:44 PM
chucks88's Avatar
chucks88
Default Re: Dumb question-Performance axle option (Red96Coupe)
I must be the exception. I replaced my 2.73's with 3.07's and had a positive effect on MPG. Went from 18 to 20 (highway @ 70)
Old Jun 12, 2002 | 08:49 PM
razor199's Avatar
razor199
Thanks Guys
This place is great for getting good advice and information! :jester
To Dumb question-Performance axle option
