Driveshaft question?
Old Jan 14, 2013 | 08:49 PM
C4vettrn's Avatar
C4vettrn
Default Driveshaft question?
Looking at a Dana-44 ds and the seller said it was fron a manual trans car. The issue is that there is a harmonic balancer/stabilizer on the tranny Yoke. All the other D44 ds's I have looked at don't have these. I know some people cut the 27.5" shafts when doing the d44 swap. Other than that did any 26.5" shafts come with them?
Randy
Old Jan 15, 2013 | 01:17 AM
WVZR-1's Avatar
WVZR-1
Randy
Dimensions are killing you it's 26.75 and 27.75
The drive-shaft could have come from any A4 to a manual trans '84 to '88 where the A4 slip-yoke would have been a fit by spline count/diameter. I've read where when it was used that it required nearly 3/4" be removed from the slip-yoke for a fit. How does it compare with your D36 yoke now? What's the dimension dampener to end of slip-yoke on both? It could also have been used in an original '84MY that a D44 was added to A4 or MT because the '84MY was delivered with a D36 regardless of transmission.
It wouldn't surprise me if the '85MY slip-yokes didn't have the dampener. An '85MY is a one year only application for the MT.
Your concern is center to center u-joint dimension, if the slip-yoke is a fit for you it's a plus BUT I'd think it needs the balance confirmed before install.
Old Jan 15, 2013 | 09:36 PM
Benny42's Avatar
Benny42
My '86L 4+3 has a damper on the transmission yoke. I have mine out on the shop floor, so
i went out and looked at it.
Old Jan 15, 2013 | 11:27 PM
WVZR-1's Avatar
WVZR-1
Yours is a factory 4+ car? If your '86 is a factory car that would indicate that '86 - '88MY cars were all with dampener! I realize the chances of this are far fetched but has a part number label survived all these years? I believe an '86 would carry a 14093173, if it were an early car an '85 would be 14084010. I always thought this was likely because of the sourcing of two different vendors for the components but until this question was asked there was no reason to ask or even be concerned.
Old Jan 16, 2013 | 07:05 PM
Benny42's Avatar
Benny42
It is a factory 4+3 car and it has aluminum heads. The driveshaft tag is intact and is 14084010 BUT... i am not the original owner & don't know the history of the drivetrain. The engine is "numbers matching" and the car had the tape drive window regulators when i got it (replaced since then). So the usual "age break" clues are kind of off for this car.
Old Jan 16, 2013 | 08:03 PM
C4vettrn's Avatar
C4vettrn
That's what this shaft ended up being from after a talk with the gentleman. I guess he claims the 4+3 is a manual trans. I don't know anything about them other than the shaft is the same length as the automatic cars and has the same dampner setup.
After talking with my local drivetrane shop they are going to cut mine down, weld and balance for $95. I haven't seen a manual shaft for close to that amount so it's a no brainer for me. Thanks for the help!
Old Jan 16, 2013 | 10:44 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Just a FYI - if you have the dampener remove it. It is not necessary and with age if the rubber lets loose you will have significant damage. I was lucky to have a spare corvette tranny to replace the damaged end of my current tranny.
Old Jan 17, 2013 | 10:19 AM
C4vettrn's Avatar
C4vettrn
Were you told this by a professional trans shop? If this is indeed the general outlook I would love to do away with it and I wouldn't need to shorten the actual shaft.
If anyone else has removed the balancer on DS yoke please post your results. Thanks!
*UPDATE* I talked with RPM transmission and they said there is no reason it can't be removed. They were nit even sure why the factory used them. Interesting!
Old Jan 17, 2013 | 10:27 AM
383vett's Avatar
383vett
I had a driveshaft along the way with the dampner. I just knocked the dampner ring off the yoke. No problems.
Old Jan 17, 2013 | 10:28 AM
85vet's Avatar
85vet
Cruise-In V Veteran
Yes!!!!! Pittsburgh Driveshaft!!!!!
Old Jan 17, 2013 | 10:39 AM
WVZR-1's Avatar
WVZR-1
You need to be concerned also about how much of the slip-yoke is inserted in the transmission and also the condition of the slip-yoke under the dampener. If you're intending to "stuff" that into the transmission you'll have a surface that is likely going to eat up seals.
The comment about removing it and using it in the same car doesn't really fit your particular needs. Buy a correct slip-yoke to go with your $95 drive-shaft modification is I believe the "right way"!
Old Jan 17, 2013 | 12:26 PM
85vet's Avatar
85vet
Cruise-In V Veteran
The amount of slip yoke that is inserted into the tranny will be determined by the length of the drive shaft. If the driveshaft length is correct the removal of the dampenor does not effect anything except that it cannot disengage while going down the highway and cause significant damage.
Yes you will have to be sure of the condition of the slip yoke and if it will work.
Old Jan 17, 2013 | 01:18 PM
WVZR-1's Avatar
WVZR-1
The Op seems to want and try to avoid shortening the drive-shaft for a fit, using his comments loosely you could only assume he means that if he didn't have the dampener then he could insert the slip-yoke further into the transmission.
Earlier I commented that I had heard that 3/4" needed to be trimmed from the slip yoke to accomplish a fit and that is what I believe would be required likely but now the surface of the slip-yoke that used to have the dampener needs to become a sealing surface to the extension seal or so it seems to me. Am I wrong? Could be! It still seems best if the drive-shaft center to center is a fit BUY the slip-yoke that will make it a fit. Why as deep into this mod would you want to start using "bone-yard" solutions?
If I had the drive-shaft in front of me I could address the situation and so could you and many
others. We don't!
I don't know that I'd trust or be very confident in a comment by RPM regarding the situation.
Old Jan 17, 2013 | 04:03 PM
C4vettrn's Avatar
C4vettrn
The slip Yoke shaft has been cut 3/4" and the drive shaft fits. The only issue is the balnacer is rubbing on the rear seal of the Tail housing. I only need about 1/8" for tolerance. If the balancer can be removed "problem solved" if shaft surface can clean up "obviously". If it is pitted or non servicable then back to plan A. When DS was on my D36 it would slide into tailshaft until it hit somthing or bottomed out inside the housing. With the 3/4" cut it will slide in tell the balancer hits. Untill I get that off I don't know how much further it can go in. The DS fits now but there is ZERO play in the system and it's rubbing on the seal. Hope this makes sense.
As long as the shaft surface is servicable/sealable and the tolerance inside/outside the trans housing is OK, I don't see why it matters what Yoke is on there? I will not run somthing that is halfassed, but there is sometimes more than one way to skin a cat "maybe/maybe not"
The way I look at it I have nothing to loose other than a Yoke
To Driveshaft question?
