broken climate control panel
Old Jan 15, 2013 | 08:52 PM
zu13's Avatar
zu13
Default broken climate control panel
not really broken..... just the manual increase button and the heat button, it is like 15 degrees outside i would like those 2 buttons to work! haha
If there is anything i could do to fix this? i couldnt find any writeups
Old Jan 16, 2013 | 09:24 AM
NCBLACKC4's Avatar
NCBLACKC4
read some time ago that the connectors need to be cleaned on the backside of the unit? mine acts up sometimes, but a smack on the dash above the unit helps.
Old Jan 16, 2013 | 07:26 PM
TiIngot's Avatar
TiIngot
Back in 2006 I had problems with my automatic climate control buttons not working and I found a post that helped my through how to remove the unit, clean the contacts and replace it. Back then dealers wanted $375 to fix it. Below is the web link to my original post that details how I removed and clean the automatic climate control unit from the dash. Hope the forum still has this link in their system.
http://forums.corvetteforum.com/show....php?t=1519199
Good luck
To broken climate control panel
