1985 Corvette 4 + 3 Z51
Old Jan 15, 2013 | 09:01 PM
Fastz51's Avatar
Fastz51
7th Gear
Default 1985 Corvette 4 + 3 Z51
I have a 85 vette with 4 + 3. I have been having problems bleeding the master and slave. I replaced both the other day. Then I some how bent the clutch pedal when the stud in the slave move out of place. So when I stepped on the clutch it felt stuck so I pressed down. Well when I went to start the car it would not start. So I did some checking and found that when I pressed on the clutch pedal it some how damaged the Clutch neutral switch. This caused the no start, so I jumped the switch and now the car starts. The problem is now I have to replace the clutch pedal assembly because the other pedal looks bent its lower than the brake. I found a clutch assembly with the neutral switch installed. Is it a hard to get the assembly out it looks like only two bolts on top and the two that hold the master in place.
