How Many Braces on your AC Bracket? 91 L98 engine
Most people say they have #5 and #9. Some say they have #6.
TIA
I made the no.6 brace on the weekend, when i replaced my water pump. (seems the No.6 bracket is rare as rocking horse ****)
oxy cut a ''boomerang shape bracket'' out of 1/4 inch steel so it does not interfere with the lower radiator hose.
See pics below first pic is brace no.5 second no.6, looks like the 90-91 a/c brackets had the no.6 bracket boss and hole.
I still think alignment between water pump and head is the key issue,
where my old pump had the heater hose return pipe contact the bracket before the bracket sat on the water pump bolts!!!.
The new water pump has everything as it should be, i put the bracket on with bolts finger tight and there is no play at all.
Note the 85 head needed a hole drilled and tapped in the head, with a 1/4 inch washer to fit between head the later a/c and bracket.
(the 84-87 a/c compressors had issues, i went thru 3 early a/c compressors before i saw the light. Oh and 1x broken 88-91 a/c flimsy bracket issue.
My current bracket has been on the engine for more than 7 years though and still going strong.
Joel
And yes, that's it hanging on the end of the water pump.
Now I'm sure there will be some folks jump on this as being just a hunk of heavy metal doing no good. It's there for a purpose.
Joel
