Flex Plate torque specs
Old Jan 17, 2013 | 07:42 PM
kilich's Avatar
kilich
Default Flex Plate torque specs
What is the torque specs for the flex plate on a 1985 Corvette? Planing on doing mine saturday.
Old Jan 17, 2013 | 08:18 PM
383vett's Avatar
383vett
I think everything that bolts onto the crank flange is 60 ft/lbs. Someone else will chime in soon with the actual number.
Old Jan 17, 2013 | 08:41 PM
John A. Marker's Avatar
John A. Marker
Torque converter to flex plate ---46 pounds
Sorry, don't find a flex plate to crank torque spec.
Old Jan 17, 2013 | 08:49 PM
WVZR-1's Avatar
WVZR-1
60 lbs ft ---- Let's leave it there unless someone posts a correction for a 2 - piece rear main
Later 1 piece L98 74 lbs ft likely a change in the fastener created the change.
To Flex Plate torque specs
